Brake Actuator keeps activating fully
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Diavolo, Apr 23, 2026.
  1. Diavolo
    Diavolo New Member
    Arizona
    Howdy there. This all randomly started happening one day, but when I go to brake, the actuator engages fully and locks the wheels, and then when I release the brake, the actuator runs for a bit. No lights on my dash, but this is undrivable. Where to start? I have techstream.
  2. JC91006
    16,923
    8,634
    You should just go and get your brakes checked. Possibly the glide pin is sticking
  3. Tombukt2
    Tombukt2 Senior Member
    13,754
    2,491
    Durham NC
    Wheels of ground is it all 4 gra bing or just rears? You should be able to press almost half travel without engaging hydraulic fluid.IE regen only . Drive on street in front of house and pull B no pedal what happened have mfd on energy mode do you see regen colors on screen pulling B???
  4. ChapmanF
    18,884
    I would start by trying to get it to relearn the linear solenoid offsets.
    The linear solenoid valves in the actuator are supposed to be able to linearly apply different amounts of fluid pressure, not just be on/off.
