Brake actuator? more frequent pump noise and occasional (!) ABS & VSC lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by avram, Jan 5, 2017.
  1. avram
    avram Junior Member
    california
    Hi all.
    I have a 2005 Prius with 176k miles (out of warranty enhancement)
    The braking system has been acting up more and more over the past few months.
    1) Occasionally (one time in 100 or so) when I start the car, the (!) ABS and VSC lights stay on for a few seconds, during which the brakes don't work.
    2) Last week, I've noticed a (brake actuator pump?) noise happens more and more often - as often as 10-20 seconds, even when I'm not using the brakes, and even for a few times after I turn off the car or open the door while the car is turned off.
    Each time it lasts about 4 seconds, but longer when I open the door after the car has been off for a while.
    3) Just today, the red triangle went on but only for a second. It happened twice while driving.
    4) there has also been an occasional "pop" while holding the brake pedal down for a few seconds after coming to a stop at a red light.
    Although the car still brakes great, I gather the prognosis is not good.
    I've read threads quoting over $2000 for a brake actuator replacement, with over $1000 just for the parts.
    Are the parts really so hard to get?
    Aren't there generics but decent new parts?
    As for used parts,
    A quick eBay search shows a used ABS actuator for under $200.
    I would still have to find a mechanic, but maybe I can find him some used parts and save $800.
    Thanks!
  2. Moving Right Along
    Moving Right Along Senior Member
    690
    541
    Through the end of 2017, all brake actuator problems on 2nd generation Prii (2004-2009) are covered by extended warranty ZG1. You can get it fixed at a Toyota dealer for free.
    Prius_Angie likes this.
  3. avram
    avram Junior Member
    california
    Thanks for pointing out that the mileage doesn't matter for the 2017 warranty enhancement.
    I saw in another post that the red triangle and/or some other warning lights have to be on before the warranty kicks in.
    For now, my warning lights come on rarely and only for a few seconds. It's the noise that worries me.
    Is it safe to drive until the red triangle etc. turns on?
    I fear the brakes will fail when I need them most.
    Thanks
    #3 avram, Jan 6, 2017
  4. Moving Right Along
    690
    541
    If the malfunction indicator is only on for a few seconds at a time, it's sometimes helpful to ask a mechanic to go for a short ride in your vehicle so they can understand what's happening and so they don't tell you they can't reproduce the warning.
  5. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    FYI, The extended warranty ZG1 still good until end of 2017 and no-mileage restrictions for Gen II. My local Toyota dealer service advisor pulled up information on computer and validated. However it seems the ABS/VSC codes needs to be present to justify fix at dealer.. according to dealer.
    #5 jm98, May 30, 2017
  6. Opus
    Opus New Member
    Atlanta
    Just took my 2009 with 230,000 miles in for this warranty service. I printed out the info from this forum and the Toyota dealership had to call Toyota to confirm but they did replace the actuator pump for free. The only issue now is that the bad pump destroyed my less than a year old Optima 12V Aux battery. Fighting with Toyota now about that. The battery has a 36 month warranty but Optima and Toyota can't agree on who to blame for this. More to come.
  7. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    I took my 2009 prius to dealership and I have 317,000 miles. I didn't have any codes, but I had loud actuator noise. They heard it and fixed it.
    So I think that some dealerships are assholes, to NOT fix an actuator that is clearly on its way to dying.
    Go to as many dealerships as you have to, to get it handled. Doesn't hurt to try that, if one dealership is a prick, maybe the next one will have better customer service.
  8. George Geisel
    George Geisel Junior Member
    Apollo Beach, Florida
    Now my 2008 was done by Toyota. Now my 2011 is worse! Toyota says NOT COVERED, Help. Let's all send letters. I already did.
  9. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Wait! Is it possible for the 12V battery to be dead because of the failing or bad ABS actuator?
    I'm just curious to learn sir!
  10. dolj
    dolj Senior Member
    7,792
    3,943
    Wellington, New Zealand
    I believe he may be referring to either the inverter coolant pump or the engine coolant pump (probably the former), although it is mentioned in passing as if we should know that already. Maybe the details were mentioned in another thread.
  11. Sydn3y
    Sydn3y New Member
    Sydney
    i-Tech
    I'm in Sydney Aust and I've got a 2007 Prius with about 200,000 km.
    Last week the 2-3 second brake actuator rattle started. I got the car serviced by NRMA who couldn't diagnose the issue but said the car was roadworthy.
    I took it to a Toyota dealership who identified the issue and quoted me $5200 for parts and labour!
    Is Toyota still fixing this issue for free? I bought this car second hand 5 yrs ago.
    Is my (gorgeous) car now a write-off?
  12. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Sydn3y likes this.
  13. Johnphoenix
    Johnphoenix New Member
    Phoenix
    I have pretty much the same issues you listed above. What worked for you? Any help appreciated
