Brake actuator replacement, car won’t turn on
Discussion in 'Gen 2 Prius Main Forum' started by Hamza Mughal, Oct 15, 2021.
  1. Hamza Mughal
    Hamza Mughal Junior Member
    30
    Virginia
    I recently replaced my brake actuator and have been scratching my head as to why the car hasn’t turned on. I did my research before posting, I checked the 12v and it is good and also the am2 fuse and various other fuses. Car has gas and I also made sure I put the traction battery plug back in. I hear the actuator turning on and off but there is no lights on the dash and no power, but every other light works, please help me figure this out.
  2. koco
    koco Member
    113
    38
    Las Vegas
    When you put the safety grip plug back into the traction battery did you push the lever down vertically after you swung it up into place?
    SFO likes this.
  3. Hamza Mughal
    30
    Virginia
    Yes I did push it back down and it is in there tight I don’t understand what it can be.
  4. Hamza Mughal
    30
    Virginia
    Could someone please help me out, I’m lost as to why it won’t start.
  5. knettle3
    knettle3 Junior Member
    38
    zachary
    Were you able to figure out the issue and get your Prius back on the road? If so, what was the problem? If not, did you have the system scanned for codes?
  6. Hamza Mughal
    30
    Virginia
    We’ll I’m having an issue now where the beeping sound went away and I have some brakes, but the cat keeps throwing codes for linear valve offset and I’ve been trying to re learn it through tech stream but It doesn’t seem like it’s working
