Brake, (!)and abs light on-sequence for jumpers
Discussion in 'Gen 2 Prius Main Forum' started by CanTG, Mar 3, 2020.
  1. CanTG
    CanTG Junior Member
    As the title says..... I know that you can “jump” the TC and CG pins (13 and 4) to get the “blinked” codes as I do not have techstream. I’ve searched and searched - can anyone tell me the EXACT procedure (just aux on or in full ready mode, do I set the jumper pins as above before powering on, etc)
    Ultimately I’d like to get an idea of what the computer says as opposed to guessing (caliber, brake actuator, linear solenoid, speed sensor, etc). 2006 Prius, 130,000 miles
    #1 CanTG, Mar 3, 2020
  2. CanTG
    CanTG Junior Member
    Was able to get the codes pulled and will search here further :)
    c1364 malfunction in w/c pressure sensor
    C1313 Open circuit in main relay 2
    SFO likes this.
  3. ChapmanF
    19,008
    IG-ON. (Not READY, not AUX. You get to IG-ON by pressing the power button two times without pressing the brake.)
    I usually fuss with the jumper first, then power on. Car doesn't care, it'll start blinking lights either way, and stop when you turn the power off or remove the jumper.
    Couple old posts with more details about it here and here. For more details than that, the repair manual (more info) never goes out of style.
    #3 ChapmanF, Mar 6, 2020
    SFO and CanTG like this.
  4. CanTG
    CanTG Junior Member
  5. CanTG
    CanTG Junior Member
    Thank you @ChapmanF - Now researching my c1313 and c1364 codes!
  6. CanTG
    CanTG Junior Member
    Because everything I’ve learned about this 2006 Prius with 130,000 miles on it from here - thought I’d share what (appears) to have fixed this (might be long!)
    My daughter was driving after a warm spell/melt, so there were lots of puddles. Suddenly, she goes to hit the brakes, brake, (!), and abs light comes on, she has no brake assist (only friction brakes).
    My husband checks the brakes, says they look good, but could be one caliper, pin seemed a bit seized, he decided to change the caliper/brake pads to be safe. No go, still no brake assist, only friction brakes, brake, (!), and abs lights still on.
    had someone pull the codes (not techstream), codes c1313 and c1364. Pulling our hair about a bit, checked fuses etc.
    Today, used the “paper clip” method (jump TC and CG pins) to clear the codes and brake, (!), and abs lights.
    everything is now back to normal! Brake assist/braking is all good. Hope this helps someone else!
  7. ChapmanF
    19,008
    Clearing the codes will often give a nice feeling of accomplishment that lasts as long as it takes for the car to detect the uncorrected issue(s) again and re-post the codes.
    CanTG likes this.
