Brake and Accelerator Same Time with Dr. Prius Overheating
Discussion in 'Gen 3 Prius Technical Discussion' started by A.J, Dec 13, 2023.
  1. A.J
    A.J Junior Member
    60
    Worldwide
    Hello everyone,
    I just got a Canadian Prius 2010 194,000km, and wanted to test the battery. Hence i had to use Dr. Prius which required i press both break and accelerator same time. Did it till battery was upto 50% and had to press both for over 3minutes, after which i saw the Coolant Overheating Icon.
    I released the pedals and it went away, but when i drive now and the combustion engine kicks in, the coolant temperature rises to 115-120 degree celsius within 1-2minutes of speeding.
    I wanted to know if pressing break and accelerator is the cause of this or just mere coincidence. I mean, i have not seen a coolant overheating error since i've been driving it for some time.
    I checked via Carista and saw the misfire error, which wasn't there before the overheating issue, so the overheating thing brought about that.
    Any help would be appreciated.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    hmmmm..isn't this the mileage where head gaskets commonly fail on the early Gen 3s? Maybe the previous owner offloaded a special deal onto you? Hope not, but sounds suspicious, especially with cylinder misfire. Is it cylinder #1?
    Or you may have a failing coolant pump, or low coolant level, or....
    Brian1954 likes this.
  3. bdc101
    bdc101 Member
    250
    usa
    What's the coolant level at?
  4. A.J
    A.J Junior Member
    60
    Worldwide
    Oh, thanks.
    Does this mean pressing brake and gas pedal simultaneously can't be the cause?
    Also, I will be changing the Head Gasket next week too incase that would also solve the issue.
  5. A.J
    A.J Junior Member
    60
    Worldwide
    It's full, but some poured off when it bubbles.
  6. A.J
    A.J Junior Member
    60
    Worldwide
    I got a new error today "OBD Code P261C - Coolant Pump "B" Control Circuit Low". Could this mean my coolant pump is not working?
  7. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Sounds like it. Assuming there's no connector, wiring, or ECM issues . Were it mine, I'd replace the water pump then monitor temps and coolant level very closely for a while. 120C is way too hot, you'll be lucky if your head gasket survived, but I wouldn't rule it out. If it does turn out to be something else you'd probably want to replace the pump anyways so that's why I'd start there given that code and the symptoms. You want to go OEM (or at least AISIN aftermarket) with the water pump on these cars, from a reputable source.
  8. Mendel Leisk
    42,341
    Freshly purchased, with 192K kms, overheating, "misfire code", there's a decent chance you bought a car with blown head gasket and seller poured a stop-leak product into the engine coolant circuit, to mask symptoms. Head gasket replacement is not trivial btw.
    BTW, using "worldwide" for location doesn't help responders.
