Brake and Gas Charging
Discussion in 'Prius c Fuel Economy' started by chicagoaficionado, Sep 7, 2012.
  1. chicagoaficionado
    chicagoaficionado Junior Member
    57
    23
    Chicagoland
    Hey there,
    Shoot me if I overlooked previously posted information, but in this video (couple minutes in)
    This dude charges the battery in drive by pressing the brake and gas. Why would you ever do this?!
    Maybe it was so for their competition so the car could be charged evenly for all competitors, but would this have any point in warming up the car? Can it even be done in the C?
    Thanks in advance.
    roadrunner likes this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you are attempting a World Speed Record, you want the maximum battery charge. In real life, never do this. (My car has a brake pedal, I hope no one installed a break pedal)
    Modifying the Prius
  3. chicagoaficionado
    57
    23
    Chicagoland
    Fixed. Sorry professor.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I do not normally correct spelling unless both spellings make sense.
    RocMills likes this.
  5. chicagoaficionado
    57
    23
    Chicagoland
    Haha I love me some homonyms.
  6. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I saw that video a few weeks back. I tried it. Would not work for me. Engine would rev a little then die.
    Dan
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Are sure you were in D? You can't force charge in N or P
  8. WD0AFQ
    619
    152
    Dexter, Mo.
    Yea, I did not like what I felt so I quit.
    Dan
  9. chicagoaficionado
    57
    23
    Chicagoland
    That's what I did too. Forgot to thank you Jimbo (y)
  10. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    Wayne is doing one of his driving clinics in this video. The reason he wanted the battery charged up to a normal level is so he can teach this guy. Im pretty sure this is after a MPG drive and the driver still learning drained his battery trying to boost his MPG. It works but as Wayne says you then have to recharge the battery and it going to hurt.
  11. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    If you press the brake pedal and hold the speed steady in drive, you waste energy period. I tried this when I first bought my 2005. Does not work
  12. fuzzy1
    10,672
    Did you do this with a 'steady speed' of zero?
  13. Andyprius1
    2,327
    859
    Cool CA
    Iv done that many times, but I thought the subject was driving and charging ( to charge more ) All sort of irrelavent now that the Prime is here. The Rav 4 driving/charging is also superior, I thought.
  14. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
    I don't understand the reason to glide in neutral. I never do that, I keep it in drive.
  15. fuzzy1
    10,672
    In the video, 2:50 to 4:30, the subject is about force charging to get the battery above the initial 2 bars to something more reasonable for instructional purposes of the clinic. He is force charging not while driving, but while stationary. Speed is zero.
  16. Andyprius1
    2,327
    859
    Cool CA
    As Iv said,
    As Iv said, Iv done that many times, actually a waste of gas.
  17. Andyprius1
    2,327
    859
    Cool CA
    So you never go down big hills, neutral = zero energy use while bringing the car up to speed and then in drive.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The steeper the hill, the more you need D, or if really steep or long, B.
    No regenerative charging ever happens in N. You are just draining the HV battery anytime you are in N.
    In N, it is just friction brakes, no regen, no engine braking. Be safe, use D at least.
    fuzzy1, jerrymildred and Andyprius1 like this.
  19. Andyprius1
    2,327
    859
    Cool CA
    I know Jimbo, I use it only to get speed up and switch to D or B quickly again.
  20. fuzzy1
    10,672
    Does this mean that you have been a student in an instructional clinic many times? Or in competitions many times where you needed to start with the battery high?
    I don't remember anyone saying we needed to do this for ordinary real life driving, only for certain special circumstances that don't apply to ordinary commuting and travel.
    I won't use N to get up to speed for big hills either.
    Gravity will do the job soon enough. By using N to get to speed faster, one also hastens the need for throwing away energy high via RPM engine braking or friction pad braking.
    #20 fuzzy1, Nov 22, 2017
