Brake Bleeding Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by likemyprius221, Jul 13, 2026.
  1. likemyprius221
    likemyprius221 New Member
    I'm new to this forum. I'm grateful that there's a place to go where I can get accurate information about my car!
    What I'm attempting to figure out is whether or not I can bleed air out of my brake hydraulic system without a scanner. I have a 2011 Prius Two.
    Here's the background with my brake problem:
    I had a brake fluid leak at the left rear wheel, I lost a lot of fluid and I'm sure got air into the system.
    I repaired the leak and now I would like to bleed the air out of the system.
    I'm hoping to gain insight as to whether or not it is helpful to disconnect my 12v battery and bleed my system with a pressure bleeder connected to the fluid reservoir. Or apply 1-2 inches of foot travel to the brake pedal with the battery still connected, but the car off, and then opening the bleeder valve on each wheel to bleed the brakes.
    Any information on how to get the air out of the brake hydraulic system without a scanner would be much appreciated.
  2. ChapmanF
    19,009
    If you are sure you got air in only at the caliper and left rear brake line, it's not unreasonable to try bleeding with some old-school method to get that air out.
    If there's any chance you got air inside the underhood components, it is much more clever to just get one of the suitable scan tools, to follow the prescribed procedure, than to dream up some clever way not to.
  3. Mendel Leisk
    42,331
    Yes you can. There's a link in my signature regarding DIY brake fluid change, using the "Non-Techstream" method described in the Toyota Repair Manual. (on a phone turn it landscape to see signatures). I've done ours a couple of times, raised all four corners (safely), removed wheels, rolled down all windows, wife helped, pushing brake pedal when required.
  4. likemyprius221
    Thank you so much for the responses, I really appreciate it.
    It looks like I should just bleed the brakes the right way with the scan tool, so does anyone have any suggestions for a reasonably priced scanner I could purchase that can do the job?
  5. ChapmanF
    19,009
    I've most recently used the Autel AP200, which gets pretty good press on PriusChat, and comes for about $60 plus a free app for the smartphone you probably already have.
  6. Mendel Leisk
    42,331
    Not sure how you came to that conclusion; the non-Techstream method is from the Toyota Repair Manual, works fine unless you’ve somehow introduced air into the brake booster components.
    CR94 likes this.
  7. ChapmanF
    19,009
    There is no non-Techstream brake bleed procedure in the Toyota repair manual.
    There is a non-Techstream fluid replacement procedure, which is what you are doing if there is no air in the system to start with, and you just want new fluid in for the old, and you will be very careful not to let any air in during the process.
    If any air gets in, the job turns into brake bleeding, which does not have any non-Techstream procedure in the manual.
  8. Mendel Leisk
    42,331
    Ah, missed that. Air in the system. Apologies. :(
  9. likemyprius221
    I decided to buy the Foxwell nt630 Plus for around $100 on Amazon and it worked well to bleed the air from the whole brake system and clear the codes. Thanks again to everyone who responded and helped me decide what to do. :)
    Brian1954 likes this.
