BRAKE BOOSTER ABS/MODULATOR NOISE
Discussion in 'Gen 2 Prius Technical Discussion' started by Rick 432, Sep 4, 2022.
  1. Rick 432
    Rick 432 Member
    112
    29
    I just bought my first Prius last week. It is a 2007 with very low mileage and seems to have been well cared for. I am in the process of changing all the fluids as I am unsure of what is new and old. So, here is the issue.
    When I open the drivers door, I hear that chattering noise from under the hood. I am told via posts here and in other forums, it is the brake booster ABS pump assembly. As I get in the car, I hear the noise when I depress the brake and start the car but as the car cycles on, it stops for a moment. As I am driving the car, every 10 to 15 seconds, the abs/booster cycles on with that annoying chattering and then stops after 2 to 4 seconds. This cycle continues when I am driving. When I shut the car down, the chattering sound continues for about 2 minutes and approximately 7 cycles. So far, it has always stopped the chatter cycling after 7 cycles. The brake system works fine with no warning lights or stopping issues.
    For me, the biggest annoyance is listening the that chattering while I am driving. I test drove a 06 Prius back in June and I don't recall hearing that noise. Is there a fix for this issue? Is this normal and did this come from the factory like that? It doesn't seem likely that Toyota would build a great car but have this tedious sounds as part of the cars normal operation.
    Thanks to all. I have read many posts here but wanted a fresh perspective, if possible. :)
  2. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    When mine started running like yours is running right now that's what was happening My ABS actuator which is the pump and the reservoir or whatever it's on one brick right behind your inverter mine failed but yet my brakes worked regular for a long time with all the lights on but that noise you're talking about I had it exactly the same times and for the same lengths if not a little longer as soon as I change that actuator all that went away vanished and I expected it to.
    Rick 432 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,471
    5,438
    Pacific Northwest, USA
    Yeah, you basically monitor how often that pump runs and once it runs too often you replace the pump. But I think you might have a different problem because if it was the brake pump running that often you'd have warning lights. So suspect the noise you're hearing is something else? Maybe the three-way heater valve? That sounds like an old computer disc drive when it fails, which is kinda like chattering?
  4. Rick 432
    Rick 432 Member
    112
    29
    Thank you. As I have second generation, I believe the brake booster and abs are integrated in the same module. I could be wrong but I believe those two units were separated in the third generation. If the unit could be services, I would gladly do that but I have found it difficult to find anyone who rebuilds these units.
  5. ChapmanF
    19,046
    Sometimes people decide to live with a deteriorating actuator until it is far enough gone.
    So how do you judge what's far enough gone?
    The pump takes 2 to 4 seconds to rebuild the pressure. That's not too different from a new one.
    Your pressure is taking 10 to 15 seconds to leak down so far that the pump has to run again. The corresponding period for a good Prius actuator, while you're not using the brakes, is hours.
    So that's how you judge what's far enough gone.
  6. Rick 432
    Rick 432 Member
    112
    29
    Thank you! My guess is from what you are writing here is the actuator is builds pressure but because of defective seals, the fluid is back-bleeding. When the pressure drops, the actuator rebuilds pressure again and so on. Makes sense! The brakes are working perfectly with the exception of this actuator issue. Thanks so much for the information! :) I only wish there was someone in the Tampa Bay area that rebuilt them. For the sake of a o-ring or similar, this could be working fine. Thanks again!
  7. Tombukt2
    13,871
    2,521
    Durham NC
    No I don't think it would be for the sake of an o-ring The one the valve start leaking internally in that big aluminum block however they got them in there whatever they did I don't know but I wouldn't imagine it would be an o-ring be great if it was there was a guy on eBay that I bought two of these bad boys from that had a rig and said he could rebuild them He sent me pictures of his setup in the shop I paid for one unit and told him that I had two cars with the problem and blah blah blah. This dude sent me another one for free and said well here you go try these and let me know how they go I didn't know if he just started this adventure or what was going on. I put these things in my shop they sat there for months. Then I finally decided to change the one in my '09 because it was time put it on and it works flawlessly I have the other one sitting here in the '05 car that was going to get it is no longer so I have an extra I guess
  8. p200
    p200 New Member
    Baltimore Maryland
    I had the same issue with the pump running as the original post. Brake pump runs for a few seconds every 15 or 20 seconds, both when driving and when the driver's door opens. (after an initial 30 second run) I could also hear a hissing sound from the engine. No codes or dash lights indicated an issue. After reading various posts, it seemed to be the accumulator. The tech at the dealer confirmed the problem for their diagnostic fee of $140.
    I ended up having the dealer replace the brake actuator which solved the issue. Now the pump runs infrequently and there is no hissing sound. Presumably the hissing is the brake accumulator (which is part of the actuator unit in a Gen 2) leaking pressure. There were no obvious problems with the braking performance, just the motor noise. After the repair the motor is more quiet when it runs. Parts were $1776 (msrp) and about $1000 in labor including bleeding the brakes. The new part is available online from dealers for roughly $1100 if you do it yourself.
    2006-2009 Toyota Prius - Modulator Valve - Toyota (44500-47141)
    google the part, I can't post a link. (I'm too new) but check to make sure it fits.
    I called two dealers in the area around Baltimore to get estimates. Both quoted the same part price but one wanted to also change the brake master cylinder for an additional $500. I went with just replacing the actuator. Hope that helps. I've had this Gen 2 for 15 years and 238,000 miles and counting.
  9. Tombukt2
    13,871
    2,521
    Durham NC
    I bought a used remanufactured whatever from a dude off eBay for $300 and I told them what I was doing and he sent me an extra one in case the first one didn't work right so I got two for 300 bucks probably overpaid but the guy was real nice and sent a picture of his test rig and all kinds of nonsense then after I installed one and it worked I was trying to find him to pay him for the other one I can't find them anywhere Nice guy
  10. yi3o8
    yi3o8 Junior Member
    38
    usa
    can you post a link or seller name for tested abs units ? That would be helpful when replacing them.
  11. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    He's lost touch with 'his guy' so you might be out of luck.
    Tom was the only guy I have seen post such a source.
    New units are available from Toyota for ~US$1140 if you shop around the online parts desk like at Camelback Toyota or Olathe Toyota.
    The other option would be to try your luck and pull a used one from a wreck or try a junkyard.
  12. Tombukt2
    13,871
    2,521
    Durham NC
    In SE USA it's VERY common to see 75K to 120K nice conditions PRII with a light hit in car totaled. In other words came out of garage got tapped enroute to Mall walking etc by retirees etc . This is their chance to get a Pacifica or ioniq5. And usually their gonna take that route. Theyres ya perfect parts car. I go to retirement communities and leave notes on them . I get lots of return calls too. Retirees are fair folks . Many retired Military like me so yworks out real well . Especially at Military retirement communities like Danberry Corp.
