Brake booster/accumulator calibration/bleeding
Discussion in 'Prius v Main Forum' started by 14 prius v, Oct 10, 2024.
  1. 14 prius v
    14 prius v New Member
    Maryland
    2014 Prius v wagon
    I'm planning on replacing the booster & accumulator on my 2014 prius v. I got the pump running every few seconds and brakes are failing intermittently.
    I'm capable of swapping the parts but I've read that there's calibration/bleeding/programming that needs done with the Toyota software/tools. I don't have those.
    Is it possible to do the swap and have a tech do that part? Do they have to do the entire repair? I'm at 1.4k with parts so I'm trying to keep costs low.
    Also, is there a way to find dealer techs to do the work? Or can a 3rd party shop do it? I'm not very knowledgeable on the toyota software/tool topic.
    Thank you.
    V Sport Wagon likes this.
  2. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    UNTIL a professional tech with tech stream or Autel does all the back end tests/bleeding you're going to have a ton of lights on and the brakes will not work properly. I would probably get it towed to someone after if you don't plan on doing the computer stuff after the install.
  3. 14 prius v
    Maryland
    2014 Prius v wagon
    Oh okay. Thanks, I thought I'd be able to drive it. Towing is an option, I was hoping I'd be able to get someone to come to me instead, like a mobile mechanic deal. But I'm not sure how to find someone that can get it done. Is there a site/group where toyota techs hang around that I can look into?
  4. V Sport Wagon
    375
    131
    Southern California
    Don't know about that. But maybe you can find a mobile mechanic in your area with a version of tech stream that can finish that for you. Either that or tow it to a hybrid shop.
  5. Mendel Leisk
    40,533
