Brake booster pump colour ?
Discussion in 'Prius v Technical Discussion' started by faisalak7, Oct 19, 2023.
  1. faisalak7
    faisalak7 Junior Member
    46
    UK
    2013 Prius Alpha
    Active
    Hi Guys, does anyone know why there are 2 colours of booster assembly (accumulater), if they have same part numbers.
    which one will you take if you have choice of 2 at scrapyard .
  2. ChapmanF
    19,047
    I think that's the first picture I've ever seen with a white label. Can't explain it. But I guess if I were at a scrap yard and needed an accumulator that would pump up and hold pressure, and I found one with a white label that did that, it would be ok.
  3. faisalak7
    46
    UK
    2013 Prius Alpha
    Active
    I took the white label one just because i was watching a video on youtube someone was changing them with brand new one and it was white , so hoping its the newer version and will have less miles covered(video is one year old) . There is no option to test them its Ebay scrapyard with 30 days warranty.
