Brake Booster Reimbursement
Discussion in 'Gen 3 Prius Main Forum' started by yiujai86, Jun 17, 2019.
  1. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    I know in another thread that there was a Customer Support Program for the 2010 model brake booster problem, but I have a 2011 and just received a letter in the mail from Toyota. I dont know if this is for all 3rd gens since it doesnt say in the letter.
    I am submitting all the document tomorrow and trying to receive Reimbursement for $3300.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    If you received the letter, it is likely it applies to you. Toyota should have your ViN on file.
  3. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    Oh right I knew that. Just wasn't sure if they expanded the coverage for 2010s to all 3rd Gens; if anyone with a 2011+ can chime in.
  4. CR94
    CR94 Senior Member
    2,824
    1,238
    Northwestern S.C.
    Interesting! I hope this means we're covered against unprovoked failures of the hyper-expensive brake components.
  5. MattFL
    MattFL Member
    193
    58
    We have a 2012 and received the brake booster letter. Knock on wood ours hasn't had any problems yet with the brake booster so I just filed the paperwork in case a problem comes up.
    yiujai86 and bisco like this.
  6. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I have a 2015 and I just got the letter. (although I used to have a 2010, I should check the VIN in the letter to make sure it's not for my old car...)
    yiujai86 likes this.
  7. ShenmueTacos
    ShenmueTacos Junior Member
    23
    Big Stone Gap, VA
  8. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I just entered the VIN of our 2015 Prius Four, but no recall showed up. I think ours was built in June 2015, so maybe the recall applies only to earlier builds.
  9. Mendel Leisk
    42,310
    You're experiencing problems? They're not just handing out money; there needs to be symptoms.
    For what it's worth, I'm noticing a kind of grunt sound, sometimes, just coming to a stop. Seems like moderate to heavy braking it happens more.
    Toyota Canada has sent out a similar letter, and I've got till November 2020 to make a claim. I've talked to the service manager about it (via email, so there's a paper trail), and his suggestion is to just monitor, and bring it in so they can test drive when it's getting closer to the deadline.
  10. Sani
    Sani Junior Member
    Kansas City Metro, KS
    I got the "Voluntary Customer Support Program" notice in the mail last week. I haven't had any warning lights come on, but I have noticed the brakes kind of go "putt-putt-putt" when I'm slowing to a stop. The dealer I bought it from replaced the front pads and turned the rotors at 91,000 miles, and it's at 129,000 now. I haven't noticed any other symptoms, so I'll probably just put a note in my maintenance spreadsheet to remind myself to take it in before 8/2021 to get checked out, assuming it doesn't show any symptoms in the meantime.
  11. Jon Watkins
    Jon Watkins Active Member
    131
    115
    Bluffton SC
    2024 Prius
    Could someone with a 15 upload a copy of their letter from Toyota on this thread? I’ve not gotten a letter for my 15 yet and guess I’ll need to call Toyota and find out why.
    Montgomery likes this.
  12. Joshman
    Joshman Junior Member
    Kansas City
    Just got the letter for my 2014. I’ve had the fairly common bark/grunt under heavy braking since 155k miles, but it’s gotten more common and under less harsh braking. So glad this support was released in case this is booster related. Thanks Toyota!
  13. Jon Watkins
    131
    115
    Bluffton SC
    2024 Prius
    Received the ZJB customer support letter for my wife’s 2015 today. Currently has 47k miles so I seriously doubt we will exceed the 150k mileage limit before the program expires for us in August 2025. Filed the paperwork away for future reference.
  14. wbeck
    wbeck Junior Member
    Atlanta, GA
    yiujai86,
    I received the same letter for my 2011 Toyota Prius. To qualify for the "Customer Support Program" (covered until 8/31/21, then secondary coverage kicks in), your Prius has to display one of the lights they show on the paper you posted and throw a code. The guys at the Toyota dealership checked and my Prius was doing both.
    My Prius has displayed the yellow "SLIP Indicator light" every time I press the brake pedal to the floor. Then the light goes away. If I normally just brake, the light does not come on. The car has done this since I purchased it used and I honestly have not noticed any degradation in braking performance. Anyway, the dealership is honoring the warranty and is replacing the faulty parts. I pick up the car tomorrow 7/11/19. I can post the receipt if anyone is interested. My Prius has roughly 59,900 miles.
    PriFi likes this.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  16. wbeck
    wbeck Junior Member
    Atlanta, GA
    A normal push of the brake pedal stops the car just fine. To clarify, in the event the brake pedal is fully depressed to the floor (which is never needed during driving), the yellow "SLIP Indicator light" is displayed every time. Pressing the brake pedal to the floor while in PARK may provided a way for folks out there to check if their Prius needs the replacement parts.
    PriFi likes this.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  18. ChapmanF
    18,995
    If you get the replacement parts, does that mean the hill-start-assist feature stops working?
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  20. wbeck
    wbeck Junior Member
    Atlanta, GA
