Brake clunking when braking
Discussion in 'Gen 2 Prius Technical Discussion' started by AllanReeves, Nov 7, 2023.
Tags:
  1. AllanReeves
    AllanReeves New Member
    San Antonio
    Hello! Just had a question on why I have a creaking/squeaking sound whenever I break and/or turn the wheel at slow speeds. I notice it on my front two wheels and a little on the back pair and was wondering how to fix it.Any help is appreciated.
    P.S. I recently had my ABS pump replaced.
    VIDEO --- I have a video but since this is my first post I'm not allowed to post it..
  2. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Very Common with Gen2 Prius... Pretty sure you can grease the pins to prevent it... But it's just noise. Never read that it could cause a mechanical failure.
  3. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Diagnosis cannot be made from here. But at the top of my list of things that I suspect is Chinese brake pads that are glued to the backing plate and became separated from heat
    AllanReeves likes this.
  4. AllanReeves
    San Antonio
    What pins exactly? I got spray lube earlier
    Will do!
    #3 AllanReeves, Nov 8, 2023
  5. Mendel Leisk
    42,364
    Probably the calliper mounting pins, which position the callipers while allowing them to shift laterally. Read up on this stuff, and there’s specific lubrication specs; just using what you have on hand can backfire.
    PriusCamper likes this.
  6. AllanReeves
    San Antonio
    Gotcha, thank you so much. I also got brake spray from AutoZone and hoping that would help a little? I used the spray lube on the bolts behind the brakes that are on the axil for the the wheel as it was rusted over.
  7. Mendel Leisk
    42,364
    FWIW on caliper pins I’ve been using Sil-Glyde Brake Lubricant. And for pad to shim to caliper contact points: Permatex Anti-Seize.
    douglasjre likes this.
  8. AllanReeves
    San Antonio
    Sorry, dumb question but do you know where those would be located?
  9. Mendel Leisk
    42,364
    The caliper pins? Take a look at first attachment in post #4. Toyota calls them “cylinder slide pin”.
  10. AllanReeves
    San Antonio
    Ahh!! That makes so much sense thank you. So if I were to spray lube on those would it help any, I'm trying to avoid having to take anything apart as I'm pretty new to this type of stuff.
  11. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Not likely and I would not use spray on grease. You need to remove the slide pins and may need to clean out the old grease. You then need to re-lube the slide pins with the correct lithium soap base glycol grease. Toyota recommends their rubber grease Part# 08887–01206 which is pretty cheap ($8 last time I looked)** for a 100g tube that will last ages.
    EDIT ** I just looked it up and it is now $11.35 Still cheap.
    #10 dolj, Nov 9, 2023
  12. AllanReeves
    San Antonio
    Okay sounds great! I'll go by AutoZone today and see if I can pick some up!
  13. Mendel Leisk
    42,364
    Have a look at the “rear brake” link in my signature (on a phone turn it landscape to see signature). It’s specific to 3rd gen rear issue, but there’s some general and Prius-specific tips, in particular a 12 volt disconnect strategy. And have a read through the attachments in post 4.
  14. douglasjre
    2,250
    751
    Null, NL
    That's where you get Chinese junk. The backing plates are glued to the pad. They separate when they get hot. You're risking your life. Avoid that store.
    DOT does not investigate cause of crashes from passenger automobiles. They only investigate commercial vehicles. They measure the brake linings. The tread thickness, the suspension, the play in the steering etc. They put the truck on a concrete pad and they walk under the vehicle to get on the stairs and they dismantle the truck after the accident. Imagine if they did that with passenger cars? I suspect there is a plethora of fatalities from Chinese parts that is yet to be discovered by the American public
  15. ChapmanF
    19,042
    Probably not easy to find the Toyota rubber grease there anyway.
