Brake codes help
Discussion in 'Gen 3 Prius Technical Discussion' started by FFgeek, Dec 3, 2018.
  1. FFgeek
    FFgeek Junior Member
    boynton beach, fl
    Hey guys,
    Can I get some help matching up these blink codes to the proper DTC codes? I can't figure out which lights match up to which DTC section in the PDFs I can find. I was on the highway last night in the rain, so I think it's just a minor error I can reset. Brakes feel fine, just all mechanical without the regenerative braking assist.
    Wheel slip/traction = 45
    ABS = 42
    (!) = 69
    Thank you!
    Matéo Kresha likes this.
  2. Matéo Kresha
    Matéo Kresha New Member
    Austin, TX
    2013 Prius v wagon
    Did you ever figure out what it was? Havening these same codes after being in the rain in stop and go traffic for over an hour.
  3. Mendel Leisk
    42,314
  4. ChapmanF
    18,998
    69 on the ECB light corresponds to trouble code C1391: the accumulator is failing to hold pressure as long as it ought to.
    42 on the ABS light means "hey, go look at your ECB code." That's also what 45 on the VSC light means.
