Brake fluid flush with Techstream
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dennis Lai, Jul 17, 2018.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    This is the G2 forum describing in detail how the G3 brakes works does not help the OP.
  2. sdrocker
    sdrocker Member
    166
    San Diego
    Quick question, how much total Toyota Dot 3 Fluid is needed? Toyota sold me four bottles of 12 FL Oz Dot 3 Brake Fluid when I told them I was looking to flush my brake system. I'm guessing I need way more than that? Also, those four bottles cost me $43!
  3. Mendel Leisk
    42,347
    I had the same question, albeit with a 3rd gen. I opted for two "pints" of Toyota DOT3 brake fluid (think they were labelled 473 millilitres, or some such travesty :rolleyes:), and they were around $7.50 (CDN).
    All the time I was draining and topping up, I was kinda keeping an eye on my supply, aiming to do a decent amount on each, more on the rears than the front (especially due to the rears being pump activated), AND end up with a slight amount in reserve, say 2 ounces, just in case I need to make an adjustment top-up.
    Right at the outset you shoot a fair bit into the reservoir, when you baste it out and refill, food for thought.
    That amount worked out well for me. I believe I asked @NutzAboutBolts and that was about what he used too? Again, that was 3rd gen. FWIW, I searched for a spec, how much brake fluid is in the car, with no luck. Seems like something that should be documented.
    SFO likes this.
  4. Sezy
    Sezy Active Member
    443
    233
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Silly question perhaps. Trying to avoid doing a brake fluid flush and wonder what would happen if I ran the steps from Techstream as if I were? Changed front brake pads a few weeks ago and starting to get the warning lights. Had everything disconnected including the relays, keys away, opened the door a lot and pumped the brakes while off. Feel there is air in the line and hoping running the procedures from Techstream could push the fluid around to remove the air the warning lights are seeing. Brakes are working fine.
  5. Patrick Wong
    18,210
    6,517
    I do not understand your hope on this. If you believe that air actually is in the system, how will the air to be removed if you don't flush the system to get the air removed as it exits out of a wheel cylinder bleeder fitting?
    Since you have Techstream, use that to clear the skid control DTC. If the same DTC comes back maybe that will motivate you to do the brake bleeding.
    Sezy likes this.
  6. Sezy
    Sezy Active Member
    443
    233
    37
    2020 Prius Prime
    Was aiming to take the lazy route, not actually bleeding the brakes but telling Techstream to do a flush. Hoping it would push air back and balance the system,fixing my brake warning lights.
    Didn't think where would the fluid go or not go before asking. Sounds like I'm best getting a bud whose done a brake flush before to help while I do the computer part.
  7. edthefox5
    10,096
    4,837
    Clearwater, Florida
    It’s not so much where the fluid goes but the trapped air. Bleed until no more air. Easy.....fill small jar with fresh fluid put bleeder hose in jar under the fluid connect hose to bleeder valve. As long as hose under fluid it cannot suck back air upon a bleed. Bleed until you see no more air bubbles in jar.
    But u still need techstream the second you open it to bleed the system will see loss of pressure.
    Sezy likes this.
  8. John321
    John321 Senior Member
    1,532
    1,444
    Kentucky
    Here is a link to video on you tube to get you started. There are other videos
    I bled my brakes back in June when I replaced the brake actuator assembly on our 2008 Prius. It was 3 months out of the extended warranty coverage.
    The old brake fluid that came out was discolored and the first supply that came out of the bleed ports for each wheel was certainly dirty. Having a helper will certainly make this job easier. Once you get the hang of using the techstream utility it won't be too hard to bleed the brakes. If you want to bleed the whole system it will take a lot of fluid, I think I used 32 oz to completely flush mine. Between the reservoir capacity and all the fluid in the actuator assy and other brake assemblies a complete flush takes a good amount of fluid. Once you get some confidence using techstream it make bleeding the brakes an easy job and it is 'neat' to command the car to do certain functions thru a laptop. You will want to familiarize yourself with the braking system components as you will be pulling relays etc to follow the techstream procedure. I printed out the portion of the Toyota Prius manual and familiarized myself with the procedures before even attempting the brake actuator replacement, calibration and brake bleed procedure. It made me feel more confident when I did it.
    Sezy and SFO like this.
  9. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Approximately ONE GALLON (128oz). FWIW, last time I flushed the entire system, due to getting air into the rear line, I think I used a little over 3quarts. It took a lot of fluid to get the air bubble dispelled.
    What services you need and what you don't | PriusChat
    Any DOT3 will suffice. WrongMart seems to be the cheapest for DOT3.
    dot 3 brake fluid - Walmart.com
    $13=1gallon, $7=1quart (4quarts=1gallon), $3=12oz bottle
    #29 exstudent, Dec 9, 2018
  10. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    I was totally thinking the same thing. Does this really benefit the system as a whole when the fluid at the rear is allllllll the way down there at the end of a dead end tunnel?
  11. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Revisiting. So my 2009 Prius (bought new in August of 2008) now has 335K miles on it and the brakes have never been flushed. I finally replaced the pads, rotors, and drums at 289K miles.
    Ironically, my in-laws bought the same car on the same day (VINs just a few apart) and their brake actuator went bad years ago at about 120K miles but after the extended warranty expired. I replaced that and used my techstream to bleed the brakes until clear new fluid was coming out.
    So the question is, would folks here still advise NOT flushing even with this extreme mileage and age?
    Should I do anything differently if I'm just flushing. No bleeding actually needed provided my helper (wife) can make sure the reservoir never empties.
    I can't remember really what I did because I think I just followed the prompts on the screen and did what it said. Actuator took about 4 hours to replace and I think bleeding the brakes was another hour or so.
    #31 sorka, Mar 8, 2025
  12. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    Well that may have been a waste of time. I tested the fluid that came out of the caliper bleeder screws. Color clear and identical to the replacement fluid. Would have expected a shade of green from the old fluid. 0 ppm copper and less than 1% moisture. As far as I can tell, it looked and tested like new fluid.
    Rears flushed using techstream. Fronts flushed using the old fashioned way except the 1.0x7mm speed bleeder screws that have one way check valves installed temporarily for bleeding otherwise it would have taken forever since I ended up losing my helper and had to do it by myself.
