Brake Fluid Loss and Brake TSB's
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jdcollins5, Oct 7, 2011.
  1. Mark57
    2,945
    2,740
    OK
    45,000+ miles and my level is @ 3/4's full.
  2. jjPrius
    jjPrius Junior Member
    68
    22
    Southern California
    20,500 miles - fluid checked last evening after no activity for ~24 hrs...fluid level at minimum mark.
    Jeff
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    This is very troubling. Fluid should not be at the minimum mark on a newish car where hydraulic brakes are practically an afterthought!
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Couldn't agree more... even after 126K on our ol Camry, I never added fluid to it or had the brakes replaced. Though it was getting close to time. :)
  5. Mark57
    2,945
    2,740
    OK
    I know from a different conversation of at least one person that was misreading the indicator lines on the reservoir tank. So here's a pic with the lines highlighted with a black magic marker just to make sure no one else is reading the wrong line. It's easy to miss the indicator at the bottom since it's dark and down below the seam on the tank.
    I hope this helps. [​IMG]
    2 people like this.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thanks Mark, totally misread that one.
  7. Mark57
    2,945
    2,740
    OK
    NP, had to put on my reading glasses and use my 1,000,000 candle power spotlight to see all the lines. ;)
    Even so, I still wonder what the average fill level looks like when they're brand new from the factory. I'd bet they're all a bit different.
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Thanks Mark. Yes, I was looking at the wrong mark also. Even though this is not the Min mark, the level has still dropped considerably from the Max mark to below the second mark in a short amount of time. I do know that all of my reservoir levels were at the Max mark when new and the brake fluid is the only one that has dropped.
    I will need to get my glasses and high powered flashlight and find the real Min mark :)
    My wife's 2007 Honda Accord with almost 60K miles has not had this much brake fluid drop in a similar size reservoir.
  9. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    The line below the MAX mark in your picture is not the MIN mark. The MIN mark is actually below the "seam" at the bottom of your picture and it says "MIN". Your picture shows the level about midway between the MAX and MIN marks, just like mine (I checked it today.)
    EDIT - Sorry, Mark57, I didn't see your picture before I replied.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ just rub it in why don't you. ;)
  11. Mark57
    2,945
    2,740
    OK
    LOL I really wasn't kidding on that part of my post. I really did have to go get my specs and high beam spot light.:D I've never needed glasses my whole life. Then, almost to the day that I turned 50, I had to start wearing 1.25x reading glasses if it's closer than about 30 inches. Major PITA from 20/20. :rolleyes:
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Same thing here :)
    I wondered why the mark below the Max mark did not have the Min text under it :confused: I would have never thought to look all the way down to the bottom of the reservoir. Of course, I would not have been able to see it without glasses and flashlight either :D
  13. El Dobro
    El Dobro A Member
    7,103
    3,282
    When I bought mine, it was filled to just above the "not this one" mark in the pic.
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I pulled my front tires off this weekend to inspect the work on the front brakes. I could see where the new bushings were added to the two bolts holding the brake caliper brackets (not sure what the purpose of these are) and the white grease added to the tabs on either end of the brake pads where they fit in the housing so they can slide easier. Other than cleaning the greasy hand prints off of the housings everything looked good. I measured the brake pad thickness and both pads showed 8 mm.
    I noticed from the TSB for the rear brakes that they will be replacing :
    Rear Brake Caliper Brackets, Shims, and Rear Brake Pad Replacement
    on my car based on my VIN and serial number. These are the parts that the dealer has on backorder now.
    Still no good explanation on the loss of brake fluid.
  15. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    ^I haven't looked at the job done on mine but after having both front and rear brake TSBs completed, it almost feels like I have a new car. That rattling was getting to me! I'll have to keep mine eyes on the fluid level henceforward.
  16. Mark57
    2,945
    2,740
    OK
    That pretty much matches my level. I suspect that's a normal level from the factory build process.
  17. jdcollins5
    5,131
    1,346
    Wilmington, NC
    It will be interesting to see, if others will continue to comment, where the majority of brake fluid levels are from the factory.
    I am 99.9% sure (there is always that little bit of doubt) that mine was filled to the Max mark. I was always impressed from day one that all 3 of my resevoirs; engine coolant, inverter coolant and brake fluid, never moved off of the Max fill marks. At least not until the last few months when I began to notice a small drop in brake fluid level each time I checked which was about every weekend.
  18. Mark57
    2,945
    2,740
    OK
    I'm sure yours probably was full. What we can do is watch the Newbie forum and as new owners post, specifically ask them to check their level and post in this thread.
    I put a pencil mark on mine and will watch it over time. I Googled around quite a bit and the consensus seems to be that there's not much expansion/contraction due to temperature changes so I shouldn't see much change just due to ambient temps.
  19. yyyiiikes
    yyyiiikes Junior Member
    84
    Austin, TX
    I will be receiving a new 2011 next week and can relay the initial level.
    3 people like this.
  20. enriquejfr
    enriquejfr Junior Member
    Winnipeg
    I noticed that the Consumers Report gives the Prius 2010 a worse than average reliability grade only for breaks. I do not know if the reason is related to mechanics reporting problems with fluid leaks.
