Brake grinding noise. Why do my rotors look like this?
Discussion in 'Gen 3 Prius Main Forum' started by kevelev, Apr 14, 2019.
Tags:
  1. kevelev
    kevelev Junior Member
    65
    ny
    [​IMG] My car is a 2011 Prius 2. I have about 130,000 miles on it. I think the picture shows what's causing the nosie,but how did they get this way? It may be difficult to see but the spots are actually low spots. I'm wondering how those areas got like that if the pads can't even contact it. Maybe its due to the brakes not getting used much because of the regenerative braking? This is the front rotor by the way and it looks similar on the other front rotor as well.
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Your picture didn’t come through but your discription leaves little doubt that the brake pads have worn down to the metal backing.
    Raytheeagle and Pluggo like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Hard to say without a picture. Can you try again.
    Just guessing, though, without knowing more about the sound, every Prius I've had has made a grinding noise when first applying the brakes after sitting overnight. It's humid here in FL and they flash rust while just sitting.
    They could also be worn out, but at only 130,000 miles that implies lots of late, hard braking. I just checked my wife's brakes on her 129k mile '07 and there's still 6-7 mm left on those front pads. They should go at least another 130k.
    Tim Jones likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    An entirely different take than I had from his post.
    Sounds like pitted rotors to me.
    Often caused by only a little use and exposure to water and winter road chemicals.
    It really isn't a problem.......except the pads will wear considerably faster.......and your grinding noise might indeed be worn out pads.
  5. bisco
    52,904
    take them apart, clean and lube, measure the pad and rotor thickness and replace anything that is below factory spec.
    rotors may just be rusty which isn't a problem, and typical for prius
  6. Mendel Leisk
    42,378
    Waiting for pics. Also, how often have you had a full service on the brakes? Ever? Toyota USA recommends tri-yearly or 30K miles, whichever comes first.
    Meanwhile, some light reading:
  7. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Found the image, just rust, good time to lube the pins, check the pads.
    The rotors can be turned, but just using the brakes will shine them right up.
  8. Mendel Leisk
    42,378
    How/where did you find the image, sure it's the OP's? I'm not sure that's rust, looks almost like some sort of glazing, with bare patches??
    Yes. I had seriously knackered rear brakes. About 6 months prior I did the rears, and completely neglected the caliper piston orientation requirement. As a result, the caliper piston was pressing on only a raised pin on the back of the inner pad, and the pad pressure against the rotor was completely skewed.
    The inner face of the rotor was about 50% rusted up, due to lack of contact. I removed the rotors, scoured them with steel wool, reinstalled everything (properly this time), and thought I was out-of-the-woods.
    But the first time I drove, it sounded horrible. An hour later, not so bad. A day or two later, had to listen hard. a week or two, completely back to normal: rotors looked uniform shiny.
    Bay Stater likes this.
  9. ChapmanF
    19,060
    Those pitted areas look at least a couple thousandths deep. I've rarely seen anything like it.
    I would take a micrometer to it across the thinnest spots (deepest pitted patches) and figure out how close it would be to minimum thickness after turning.
    Is it like that on both sides? If there's a place with deep pits on both sides lined up with each other, that's an easy measurement ... otherwise it's a bit of a math exercise: measure the "unpitted" thickness at some spot where there's no pit on either side; measure at some spot where one side's pitted and the other side's good; subtract to get the depth of that pit; same for a spot where the other side's pitted and the first side's good; subtract both pit depths from the unpitted width to get an idea where you'll be after turning.
  10. BZzap!
    1,607
    878
    That picture looks like corrosion. Salt perhaps. When I wash my car and let it set you can almost sit there and watch the rotors turn red with surface rust. They sound like metal to metal after the first brake application. I can just imagine what the rotors look like after sitting a week or so after they’ve been subjected to road salt. The Toyota rotors are basically low grade pig iron and are very susceptible to the elements.
  11. bisco
    52,904
    if that is the o/p's pic, replace the rotors
    scona and padroo like this.
  12. kevelev
    65
    ny
    Thanks everybody for the advice. The picture was correct, sorry for it not showing up right away. I drive my car almost every day, so any surface rust does get removed pretty regularly. These have been exposed to road salt as well. I try to drive as gentle as possible to make everything last, so I definitely think that the rotors have had minimal pressure applied to them (whenever possible, I use regen braking). About 4 months ago I lubed the pins and made sure everything was aligned. Maybe I need to do a few hard stops, or somehow clean the rotors? I can try hitting them with some brake cleaner.
    Bay Stater and Mendel Leisk like this.
  13. bisco
    52,904
    my daughter and i have put almost 300,000 cumulative miles on three different pri, from vermont to mass, and i've never seen rotors that looked like that. the area under the pads is always smooth and shiny.
    those look defective or something
  14. ChapmanF
    19,060
    I suspect it'll take more than some hard stops or brake cleaner to fix those. A brake lathe ... now that might just do it. :) If the micrometer shows the minimum thickness is still enough to get away with it.
    jerrymildred likes this.
  15. jerrymildred
    11,517
    14,171
    Tampa, FL
    Those look like voids in the casting, but I know they almost certainly would not have made it onto your car in the factory like that or past your eyes when you lubed the pins. :confused:
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    That's easy for you to SAY. Would you actually do that yourself on your own car ??
    Somehow I think not.
  17. bisco
    52,904
    why do you say that? i would take it to a mechanic and have it done.
  18. Mendel Leisk
    42,378
    I've got the dial indicator (with magnetic base), and micrometer, and the Repair Manual specs. I try to check out the rotors at least one time. They're rarely anywhere significantly lower than new thickness, but the runout can get a bit iffy. I just carry on. It takes me longer to fold the magnetic base so it fits back in it's case than to do the measurement, lol. But I always insist on doing that, my cross to bear, har har.
  19. ChapmanF
    19,060
    You mean, look in the manual for the specs, measure things, and replace them if they need replacing, as directed by the manual?
    It's what I do. You didn't explain why you "think not."
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    But that is NOT what you said.
