Brake "Honking" Noise - Bad Actuator Help please
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zodeo maxwell, Mar 8, 2020.
  1. ChapmanF
    19,045
    Customer Support Program ZJB Phase 2, if I'm not mistaken, covers 2010–2015, as long as you are within ten years of the date of first use, and under 150,000 miles.
  2. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Look, what caused these expensive failures is not the nitrogen leaking out, is that something breaks inside the brake fluid lines in the brake actuator, the one that has the ABS integrated into it, the leak caused the fluid to flow back into the reservoir somehow, that is not supposed to happen regardless if there is nitrogen or not, nitrogen is there to help reach pressure faster, not to hold the fluid into place. Maybe a valve fails, a line breaks inside, i do not know because i have never opened one. Fix My Prius could replace his if he wants now, before his pump starts to run more until it runs so much that it burns.
  3. ChapmanF
    19,045
    I agree that it's more commonly the internal leakage of fluid.
    Failures associated with loss of nitrogen are a different failure mechanism—not to be confused with the internal fluid leakage, but simply to be understood as another independent way the system can fail.
    When nitrogen leaks from the accumulator, two things happen: (1) you have less of it in the accumulator, where it belongs, and (2) you have some of it in the brake fluid, where it doesn't belong. You can fix (2) by going through a brake bleed (and lo and behold, bubbles come out of a system that had never been opened to let air in). That, of course, doesn't fix (1), but (1) doesn't have very noticeable effects until quite a lot of the charge has been lost.
    The effect (2) is noticeable for making honk noises, and is probably a factor in the rarely (but not never) reported "floored pedal no stoppie" failure mode.
    Sonic_TH likes this.
  4. Fix My Prius
    Fix My Prius New Member
    Tucson, AZ
    This is a graph of the ABS modulator function. I need to replace it; just wish I didn’t have to.
    Within the past two months, I’ve done so much work to this car for someone who is not a mechanic (a car that has 420,000 miles on it). I replaced the old HV battery cells with new Nexcell lithium cells, cleaned the EGR valve and intake manifold, replaced spark plugs and ignition coils, replaced shocks and struts, and cleaned the fuel injectors. Now I have codes B1442 and B1443 - though climate control actuators seem to be working fine. Do I really want to replace the ABS modulator on a car that has 420,000 miles on it? I’ve never bled brakes in my life (though I bought the Launch X431 Elite with good intentions), let alone replaced a Prius ABS modulator, but why stop now?
  5. ksyolsen
    ksyolsen Junior Member
    66
    28
    Haslett, MI
    2013 Prius v wagon
    Bought a 2013 Prius V with 165k on it last month. Yesterday I experienced this honking sound coming from the brake pedal area for the first time. Sounds like it isn't necessarily a huge concern, but could signal the brake booster/actuator going bad eventually?
    Is there anything I should do to help it along? or just leave it be? (I don't want to touch it if it's going to possibly make it worse).
    I plan on doing a brake flush, but not the full ABS flush, just the brake lines to each of the calipers, since I have to replace the rear calipers anyways. Should I plan on doing the full flush? If so, what do I need and how complicated is it? Risk of increasing the damage/rate of damage? hmm
    Thanks in advance!
  6. CR94
    CR94 Senior Member
    2,834
    1,244
    Northwestern S.C.
    If you search, I think you can find an old PriusChat thread with detailed bleeding instructions.
    ksyolsen likes this.
