Brake light and ABS light just came on! Please advise!
Discussion in 'Gen 2 Prius Main Forum' started by Funk-O-Meter, Apr 5, 2013.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Your confusing this hijacked post with the op. Understandably as it made this thread very hard to follow.
  2. marblekit
    marblekit Junior Member
    Orange County CA
    I'm getting this same issue as well. I had my inverter pump replaced under the recall about 5 months ago. The pump seems to be making vibrations I can feel on the tube to the coolant tank, and the lights don't come on right away, only after the car has been running for 20-30 minutes. Even when the lights are on, the car drives normally. I suspect the pump may be working at less than full capacity or something is preventing optimal cooling of the inverter... is there a way to tell or do I have to take my car to the dealer?
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Open up the coolant tank next to the inverter and look inside while the car is running. You should be able to see ripples on the surface, showing that there is fluid flowing.
