Brake light out on my prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by owabim, Oct 3, 2011.
  1. hormosapiens
    hormosapiens Junior Member
    44
    north Jersey
    Parking, reverse, right/left turn are bulbs. just buy new bulb and replace them if they burn out. but if the brake light which are LED's run out you have to replace whole assembly as mention above.
    52,837
    wow, that seems crazy.:eek:
    Starship16 likes this.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Sorry "bisco" it's true.
    John (Britprius)
    52,837
    i see in the early posts, someone mentioned that this was a 'mistake' by toyota, i couldn't agree more. that being said, my neighbors '04 is still fine, so i guess you can't complain about 10 years of service.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    This is the direction all manufacturers are taking.....look at BMW, Mercedes, Honda, Chevy, Kia etc.
  6. dbo83
    dbo83 Junior Member
    I replaced the assembly after checking for 12V to the LED board. Found one for $73+s/h on Amazon, AutoHalo.
  7. 2004priusgal
    2004priusgal Junior Member
    76
    new jersey
    Upgrade
    2004 prius - bought new tail lights (because of those dimmed leds) 155k. voltage checks at the connector ? - should all be 12v or lass? mid left one is 30v? cant find values anywhere ,so assuming it should be 12v or less.
  8. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Let me guess....
    When the Gen4 LED headlight or brake light burns out, a replacement bulb will cost $3,478! :eek::eek::eek: :ROFLMAO:
    #48 Starship16, Sep 15, 2018
  9. Patrick Wong
    18,210
    6,517
    Your assumption is correct and therefore I question whether your meter is working correctly. Start with something simple like measuring the voltage across a 9V battery. A new battery should measure 9.6V or so.
