Brake Light Wiring for Flasher module
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jessemkane, Jan 4, 2018.
  1. Jessemkane
    Jessemkane Member
    44
    111
    Illinois
    Wanting to install a brake light flasher module on my actual tail lamps and NOT the 3rd brake light. Does anyone know where I can tap into the main wiring for the tail lamps before it splits off to each side? I just need the main power wire is all really. HELP!
  2. Elektroingenieur
    2,515
    3,282
    Three Touring
    There is no such point in the circuit; the branch for the left and right sides is taken before the branch for the center stop light, which comes from the left side. See the Stop Light pages in the System Circuit section of the Electrical Wiring Diagram, available by subscription to techinfo.toyota.com.
  3. Jessemkane
    Jessemkane Member
    44
    111
    Illinois
    There has to be a spot somewhere between the pedal switch that activates them and the lamps where its just a single wire running to the back, that's what I am looking to find. It doesn't need to be in the rear of the car and I expect it to be under the dash somewhere, can't find info where anyone else has done this yet so if I find it I will post the answer.
  4. Elektroingenieur
    2,515
    3,282
    Three Touring
    There is no one wire that would allow you to switch the left and right stop lights without also switching the center stop light. If you don’t mind switching all three lights together, then you’re looking for the green wire between the A28 stop light control ECU assembly (also called the stop light control relay), pin number 1 (OUT), and the A50 junction connector, pin number 7.
    HeadOfJarg likes this.
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    It may not be street legal to do that depending on your residency of state because it strobes in unison with the other brake light. Turn signal bulb dead strobe will be okay because its only one light, not a pair. But I do see some here in CA with the double brake light wa/rning flash 3 times quickly then constant on.
