Brake lights. Anti skid. Tpms abs all on. Pump keeps cycling on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rrrolfff, Sep 27, 2019.
  1. Rrrolfff
    Rrrolfff Junior Member
    77
    Irvine
    Pump cycles like each 2 seconds. Help please!
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    You got a leak in accumulator
  3. Rrrolfff
    77
    Irvine
    Do they normally leak - or is the line more common - how hard is the accumulator to replace?
  4. Rrrolfff
    77
    Irvine
    So the level was a little below , I put in maybe 3 ounces to top it, now no lights (???). Iys lookingbto be possibly intermittent (???)???
  5. bisco
    51,831
    if that solves it, that was the problem. if the lights come back, look into the extended warranty, not sure if you're covered
    tankyuong likes this.
