Brake Noise - New Pads and Rotors
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chicken G, Jul 25, 2018.
  1. Chicken G
    Chicken G Junior Member
    Hartford CT
    I have a 2012 Prius V wagon with 70K miles on it. Had all pads and rotors replaced about a month and a half ago by a "Brake and Muffler" place. Shortly after I had a rubbing noise coming out of the back brakes, which went along with the tire rotation when I started driving in the morning. I chalked it up to some moisture getting between the pads and rotors overnight. It would go away if I hit the brakes a few times. A week after the new pads and rotors continued to make noise so I brought it back to have the "brake and muffler" place look at it.
    They told me they greased everything up, shimmed the pads and everything sounded great.
    The next day, exactly the same noise. Two weeks passed of me dealing with the noise and I finally bring it back to the "brake and muffler" place. They tell me the pads and rotors are under warranty and that they would try new pads and just turn the new rotors down a little. Sure, sounds great to me.
    Car is returned to me with no noise. The next day also no noise. Two days later, the noise starts back up, but now it's even worse than after the original pad replacement. I think when they replaced the pads this time, they didn't shim them like the first time. Again, the noise goes away after I hit the brakes several times, but it does take longer to go away than original pads. They are now trying to tell me that I probably need to replace the rear calipers because they contacted someone at a local Toyota dealership and were told that usually pads, rotors and calipers for these should be replaced as a set. I think they are trying to feed me a line of crap.
    I also should note, the front brakes have not made any noise during this time.
    Any help or suggestions?
  2. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    "Brake and Muffler" place like Midas and others shops usually use mediocre aftermarket pads and shim kits to save 10 bucks off the parts cost, that maybe one reason for the brake noise. Another thing maybe due to rust from over night moisture and when being driving and brakes applied, the pad is wearing down the rust thus making the brake noise?
    Grit likes this.
  3. CountryGolden
    CountryGolden Junior Member
    MI
    Replacing calipers seems like overkill. My guess is that the caliper guide pins need lubricating. The lube dries up over time and causes the brake pads to not retract fully, potentially causing the rubbing noise you're hearing.
    Chicken G likes this.
    49,507
    welcome!
    i believe there is a special technique for orienting up the rear caliper piston correctly.
    why did you need new pads and rotors at 70k? that is really early for a prius.
  5. ChapmanF
    15,664
    It is normal and common for any Prius to make rough brake noises after being parked in a damp environment, and for the noise to go away after several stops. It goes away faster if you shift to Neutral and make a couple of normal stops that way, which eliminates regen and forces the brakes to do all the stopping, and clears off the flash rust faster.
    The noise will be back again any time the weather has been damp enough while the car was parked, and will go away again with the same treatment. As long as that's what is happening for you (has the weather been damp on those occasions?), it does not indicate anything amiss with the brakes.
    -Chap
  6. bisco
    49,507
    he mentions that in the o/p, but unless he just got the car, he should have heard the rust many times before.
  7. Chicken G
    Hartford CT
    Thanks! It did not happen until I had new rotors and pads put on. I suspect they didn't put the correct shims in and it has also been extremely humid in New England the last month. Both probably causing the issue.
  8. bisco
    49,507
    i get the scraping sound every time i overnight the car in the garage in this humidity. but it wears off quickly. that's how you know it's just a light coating of rust.
    #8 bisco, Jul 30, 2018
  9. Mendel Leisk
    38,735
    The v has different rear brake, with a mini-drum brake integrated into the rotor, so I think doesn't have the piston caliper orientation issue.
    Still, something is going on, and I would lay this on the doorstep of the good ol' "brake and muffler" place.
    @Chicken G at this point, I would just eat it, bring it into a dealership service department, see what the heck is going on. Hopefully just the rears.
    Before taking that plunge though, feel the rear wheels after a decent drive, see if they're warm. Compare to the fronts. They should just slightly warm at most.
    If you have the wherewithal: chock the front wheels, raise the rear, and see how free spinning the rear wheels are. In a pinch you can do this one rear corner at a time, with just the scissor jack. Be sure to securely chock the diagonally opposite front wheel. Get proper chocks, not just a block or rock:
    Chicken G and bisco like this.
