Brake Override Malfunction. Car won't start.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by I_commute_to_work, Dec 27, 2019.
Tags:
  1. I_commute_to_work
    I_commute_to_work Junior Member
    Southern California
    2015 Prius c
    After a couple of days parked I got the following error in my Prius C 2015:
    "Brake Override Malfunction"
    Now the car won't start. I doesn't even respond to the keyless door lock. If I remember correctly, it also said to contact the dealership.
    It also made a weird continuing noise, the likes it alwas does when turned off. Kinda like a suctioning vacuum.
    Isn't there a correct sequence to start ? eg. press the brake and push the start button. I might of not pressed the brake this time. IDK.
    Could the computer be reset ? Any ideas ? Thanks.
  2. I_commute_to_work
    Southern California
    2015 Prius c
    UPATE: I had a hunch the auxiliary battery was discharged. I removed it and now it's charging externally. Will update.
    PriusCamper likes this.
  3. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I was about to suggest to check the 12v battery. Those things last about 4-5 years.
    dig4dirt likes this.
  4. I_commute_to_work
    Southern California
    2015 Prius c
    UPDATE: I removed the 12v battery and after around 11 hours of external charge ( using DieHard 71219 6/12V Shelf Smart Battery Charger and 2A Maintainer ) the car started normally and drove around the block without error messages.
    IMO The culprit was the lack of use for about 3-4 days and a voltage drain from a small QYT KT-8900 ham radio I had installed. I read somewhere, if I remember correctly, those radios draw around 20 milliamps when turned off.
    I disconnected that sob.
    I will soon consider (1 year max) replacing this 12 v battery anyway to prevent any future surprises.
    dubit likes this.
