brake pad fell apart on 2002 at 43,561 miles
Discussion in 'Generation 1 Prius Discussion' started by Londonderry, Feb 5, 2011.
  1. Londonderry
    Londonderry Junior Member
    35
    16
    wish I knew
    2002 Prius
    I
    The threads I've read are consistent in describing air being drawn from the cabin, to the underside of the hybrid battery pack and away from the top of the battery pack to the "outside". So far, I have found no mention of the temperature impact from 3 of the 4 openings, in the terminal portion of the vent duct, discharging into the trunk space. If the thin trunk liner is in place, the air discharged under it seems all the more likely to accumulate heat inside the vehicle rather than removing heat, and to accumulate/concentrate the heat in the area of the auxiliary battery and driver's side portion of the hybrid battery. That area could be useful for keeping coffee hot but seems unhealthy for batteries. It also makes the trunk hotter than conventional cars and poses a hazard for whatever might be transported in the trunk by an unsuspecting driver.
    BTW, although there is a "hot" connection with the original theme of brake pads falling apart, I've read enough posts to think this should be started somewhere, somehow, as a new topic. I have no clue how that would be done effectively.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    Air is drawn from the passenger cabin, washes through tiny, narrow channels between the modules, then exits the car at the fenderwell. It does not vent into the cabin. The interior of the case contains foam to prevent air leakage on the terminal end. To say the battery case is airtight would be an exaggeration, but there are no significant outlets other than the exit duct.
  3. Londonderry
    35
    16
    wish I knew
    2002 Prius
    I
    I am referring to the last portion of the battery ventilation system in the 2002 Prius, the "Quarter Inner No. 2 Duct" aka Duct, lower fan part # L 62934-47020. I realize the system was changed considerably in the 2004 and later models. I can find pictures which include the part I'm wondering about but I have not been able to copy them here. There is no foam involved with this part and it vents to a louvered opening in the left rear quarter panel but also has 3 unobstructed openings into the space inside the trunk, between the trunk liner (interior trim) and quarter panel, thus creating a heat pocket.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Ah you have a 2002/GenI Prius. My above explanation was for the GenII and above which as you state is completely different and has no correlation. I am not familiar enough with the GenI battery venting system to provide useful info. I tend to focus on GenII and GenIII.
  5. ChapmanF
    18,220
    The louvered opening is a small supplementary vent for this system. The largest exit passages for cabin air from your Prius are those aft in the rear fenderwells. Fold away the trunk liner, reach your fingers way down aft of the 12-volt battery, and feel for the rubber-flap check through which air leaves the trunk, hidden by the rear bumper. That's what happens to your battery-duct air, after it has been released over the 12-volt battery and conditioned that space too.
    Does that unravel the mystery a bit? :)
    -Chap
