Brake pad replacement
Discussion in 'Gen 2 Prius Main Forum' started by pafoss, May 13, 2006.
  1. bstephens
    bstephens Junior Member
    36
    Oklahoma
    I also turned over 200,000 a few weeks ago, and thought the same thing. But it turns out my front pads still have 50% of the pad left.
  2. moshe_levy
    moshe_levy Junior Member
    62
    I'm in the minority here, clearly, but my front pads were gone at 80,000 miles. I had them replaced at the dealer. The rear drums still have lots of meat left on them.
    -MKL
  3. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I have just been told I need to replace my rear discs due to excessive corrosion at 120,000 the pads have plenty on them but will replace discs and pads together, fronts are at around 70%
    Someone made a good point about the salting of the roads, I knew I should of got those moon discs.:rolleyes:
  4. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    For rear discs try Jolly good car spares (ebay) £16.99 the pair made by National brake disc (Newcastle). If you wan't telephone number he will deal direct PM me.
    John
  5. Britprius
    5,194
    1,921
    I replaced my discs all round this morning. Fitted new front pads, but used old rear pads after surface grinding them because there was still at leased 75% life left in them.
    Car has done just over 80,000miles, but the discs were very rusty. Front pads still had 4mm left on them but I believe the UK pads are softer than the US pads to give more brake feel.
    Total time to change including resurfacing pads 2 hours, total cost £67 ($100/110).
    If you think the bit of the discs you can see are rusty wait till you take them off and see the backside.
  6. Classic_pri
    Classic_pri Former 2001 Prius 0wner
    115
    31
    Wisconsin
    Browsing idly today, I noticed that Hawk makes HPS pads that fit the Gen II Prius. They'd probably wear the rotors a little quicker than stock, but that might help keep the corrosion under control.
    Hawk makes some of the best brake pads on the market IMHO.
  7. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Well thank you John, I have got them already now, but I will check with them when the fronts need doing.
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    In my experience with multiple cars (particularly those parked outdoors every night) that's where the real rusting is found. I make it a point to look in that direction when I'm under the car for oil changes.
    Probably not so much a problem for desert dwellers and those where they don't salt the roads.
    - Chris
