Brake Pad Thickness specs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mossypete, Oct 1, 2004.
  1. mossypete
    mossypete New Member
    16
    Berkekey, CA
    anybody know the brake pad/shoethickness specs for the prius.
    Just had a 15K service/ssc40D done - but I picked it up after the shop was closed and didn't get a chance to ask the tech what the starting/replacement brake thickness specs are -
    My fronts are at 9mm rear at 4mm - I've got no feel for those numbers.
    I'd always assumed the prius woud get better brake pad life than a non regen braking car unless they use thinner pads/shoes to save weight
    TIA
    Pete Moss
    Berkeley, CA (one of hundreds of 2004 prii in my town)
  2. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    Hello Pete,
    Desribed in the Japanese NHW20 Technical manual, followings are spec...
    Front disc pad: new 11 mm, limit 1 mm
    Rear shoe lining: new 4 mm, limit 1 mm
    Regards,
    Ken@Japan
