Brake Pads wearing crooked???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gertsprius, Jul 26, 2018.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Thanks Mendel. Reading your past posts on brake maintenance procedure, I made sure that the X was properly aligned. I followed @NutzAboutBolts videos on caliber slide pin maintenance and brake pad replacement. :D
    NutzAboutBolts and Raytheeagle like this.
  2. Bay Stater
    534
    771
    Central Mass
    It probably was... Although I an not the original owner. Yes I was aware of the brake inspection schedule via reading PC. Just procrastinated. :(
    Mendel Leisk and Raytheeagle like this.
  3. Mendel Leisk
    42,309
    Still, check the rear brakes for excessive drag.
    I haven't completely got my head around what's going on, but my sense is: you really want to ensure that the brakes get well seated, with the piston in that X orientation. Avoid using the parking brake (which will try to rotate the piston), pump the brake pedal multiple times, then take short test drive. Then do parking brake apply/release a few times. Then raise the rear and check the wheel spin.
    Trust but verify, lol.
    #23 Mendel Leisk, Apr 14, 2019
    Bay Stater and Raytheeagle like this.
