Brake Pedal Click
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by keymusic, Nov 18, 2016.
Tags:
  1. keymusic
    keymusic Active Member
    211
    113
    Southern California
    Thank you but the sound you're describing is something different than what I'm talking about.
  2. Tissimo
    Tissimo Junior Member
    San Carlos, CA
    Four Touring
    I also have this dreaded click. Same exact behavior, press to the left and it clicks every time even when car is not on. You're probably right that it's something metal to metal. I'll need to assess a bit more and see if there's to dampen it. Thanks for posting and starting this thread.
    I'm wondering if this is where the clicking is occuring.
    keymusic likes this.
  3. keymusic
    211
    113
    Southern California
    It's possible that's the spot.
  4. The1obster
    The1obster Junior Member
    Three Touring
    First post, I came here because I am having the same click. It's not the brake light switch. Keymusic can you tell me what to bend, I'm willing to go that far as I can not stand it anymore.
  5. keymusic
    211
    113
    Southern California
    Sorry but I don't really know exactly what I did. I describe it the best in this post Brake Pedal Click | Page 2 | PriusChat
  6. The1obster
    Three Touring
    Keymusic, I'm assuming your click is still gone? Do you remember where you stuck the screwdriver on that bracket/pin/bolt (thanks for the pictures), and where you relived the pressure? Going to try and fix it tomorrow morning.
  7. keymusic
    211
    113
    Southern California
    Surprisingly the click is still gone. I'm sorry but I really don't know what did the trick. I just put a flat head screwdriver everywhere it would fit between things and tried to basically stretch things. I didn't test it after each place I tweaked. It just no longer had the click after I had messed with everything. I didn't do it in a very methodical way, which I normally would, unfortunately.
    RCO likes this.
  8. Tissimo
    San Carlos, CA
    Four Touring
    The1lobster hope you're able to solve it. My click is still there and probably getting worse, clicks when pressing and clicks depressing. I haven't had time to muck around with it.
  9. 4thGenPriusOwner
    4thGenPriusOwner New Member
    New Jersey
    2012 Aqua
    Three Touring
    Hello keymusic,
    Thank you for your post. I just bought a 2017 Prius Touring 3. My second Prius. My first was 2008. 6 days later, after driving 200 miles, I started hearing the click!!! Took back it to the dealer. Service tech said something in the brake pedal assembly needed to be replaced. Good thing I mentioned it. I originally took my Prius back because the front passenger speaker was not working -- had a static sound. That is getting replaced. Will keep you posted.
    The1obster and RCO like this.
  10. keymusic
    211
    113
    Southern California
    Wow, can you please post exactly what they did so I can tell my dealer? Thanks
    The1obster likes this.
  11. 4thGenPriusOwner
    New Jersey
    2012 Aqua
    Three Touring
    Absolutely. Brought my Prius in on Saturday. They have to order the part. I hope to have my Prius back by Saturday. Thx!
  12. keymusic
    211
    113
    Southern California
    Do you know the part name or part number?
  13. Prodigyplace
    12,708
    11,847
    Central Virginia
    They probably will, once they get the car back.
  14. keymusic
    211
    113
    Southern California
    Sometimes you get a work order from the dealer that shows the part that was ordered before the work is done.
  15. 4thGenPriusOwner
    New Jersey
    2012 Aqua
    Three Touring
    Just looked up my work order online. It says "Install Parking Brake Clip". I will post details when I get my Prius back. Stay tuned.
  16. keymusic
    211
    113
    Southern California
    Thanks!
  17. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The "Install Parking Brake Clip" is the safety recall to do with the hand(foot)brake.
    kithmo, RCO and krmcg like this.
  18. 4thGenPriusOwner
    New Jersey
    2012 Aqua
    Three Touring
    Yes, u are correct. I just looked logged onto my dealer's website for my Prius and it indicates that there is a recall. I guess that is being done to my Prius in addition to the other issues. That probably explains why the speaker and "clicking" issues are not displayed on the website -- they have not been fixed yet. I will update when I get my Prius back. Thanks!
    Prodigyplace and alanclarkeau like this.
  19. keymusic
    211
    113
    Southern California
    Ooooooo. Well that's different then.
  20. Prodigyplace
    12,708
    11,847
    Central Virginia
    Please update your User Profile to show your new ride. That helps us provide proper help if needed.
