Brake question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, Jul 15, 2016.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    2010, purchased new, 91,000 miles, in for free dealer inspection today. I should point out, this is an honest, reliable, and trustworthy dealer, I've purchased 7 cars from in 20 years. Car passed , but I'm informed I will soon need rear pads and rotors - Rust, grooved pads, estimate $395. Brakes are original. Pads are LR 3, RR 4, and Rotors are LR 8.55, RR 8.50. I do not ride the brakes, and I do not brake hard. Also, I do little stop and go driving. Environment, Southcentral Pennsylvania.
    Is this typical of this model, and is the pricing in line?
  2. JC91006
    16,898
    8,629
    $395 for just rear brake pads is crazy expensive. I think you'll be good for another 30k miles before you have to worry about it.
    Look for coupon specials online from that dealership or a neighboring dealership. I think they have specials for probably half that price......and even then I still consider that expensive
  3. lenjack
    804
    114
    Pennsylvania USA
    Thanks.They did say pads and rotors.
  4. JC91006
    16,898
    8,629
  5. JC91006
    16,898
    8,629
    you can just machine the rotors, no need to replace them unless they are in really bad shape. remember most of your braking is electronic......and using front brakes. The rear brakes are not doing that much
  6. fuzzy1
    10,647
    ... except rusting, which can cause frozen calibers and dragging problems. Is this in a region that oversalts the roads in winter?
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I don't know of any manufacturer that recommends cutting rotors. Ventilated rotors with advanced metal technology don't have to have much of a lip to be out of specification.
    $395 for pads and rotors sound like a fair price. Even at 3mm you have a bit remaining.
  8. lenjack
    804
    114
    Pennsylvania USA
    No, not that much salting. While I said I trust the dealer, I don't know the service advisor. He may be new, and trying to score some extra points. From the specs I've shown, is this normal for this car? He says I can do another 10k without worry, about 8 months for me. There's a local gas station owner in town who does this, and I trust him. I think I'll have a chat. I though Prius electronic brakes lasted forever.
  9. bisco
    52,647
    2010's are notorious for this in snow area's. there have been quite a few reports here, of rear brakes and premature wear.
    the slide pins freeze up and prevent the pads from opening properly. toyota recommends regular inspections and lubrication if needed, but most dealers don't bother.
    if you keep the pins lubed, you won't have a problem.
    98,000 isn't bad at all, we've seen under 40k iirc, and i think 400 bucks for pads and rotors are a great price.
    if you do go local, make sure they understand prius brakes, they're tricky. all the best!(y)
  10. Mendel Leisk
    42,119
    Service limit for the rear rotors is 7.5 mm, so machining the rotors might just do the trick. I've purchased a set of rear pads and shims myself, prices as follows (in Canadian dollars, August 2014):
    pad set, brake p/n: 04466-76012: $99.69
    shim kit, brake p/n: 04946-47070: $16.77
    The reason I was doing the rear pads was due to my earlier error at rear brake assembly. I'd opened them up, and neglected to align the pin on the pad backing plate to be between spokes on the face of the calliper pin face. This is crucial for brakes to perform correctly. Neglecting this, the brakes will drag badly, score the rotors, and skew the pad to rotor contact.
    The inner face of rotor in my case was only about 50% making contact, the rest rusty. The outer rotor face had significant scoring. Still, just removing and steel wooling the rotors, then carefully installing fresh pads, with the pins correctly locked with the caliper pin cross pattern, a month or two down the road the rear brakes behaved (and looked) like new.
    I would suggest as a DIY: chock the front wheels, jack up the rear (there's a rear centre jacking point shown in the manual), ensure parking brake is released, and try spinning the wheels. A slight amount of drag is normal, but if they're really fighting pin misalignment could be the issue.
    $395 is a little steep all-in, not bad though if it's including new rotors.
  11. lenjack
    804
    114
    Pennsylvania USA
    Thanks all. Will talk to my local guy, who is also a good friend.
