Brake repair: Where to go?
Discussion in 'Generation 1 Prius Discussion' started by jmelton, Feb 23, 2014.
  1. jmelton
    jmelton New Member
    2001 Prius
    I've had major brake issues with my '01 Prius. I've had the front and rear disks, pads, etc. replaced but the brakes still aren't right. When I step on the pedal it often though not always (so far) sinks to the floor without "grabbing" but will catch if I pump the brake. I'm guessing based on what I've Googled this weekend that it's the master brake cylinder, but the place I took it says they're really not sure and is leaning toward saying I should take it to the dealer. I do NOT want to take it to the dealer if I can help it. I took it to them when I first had brake issues and they said the problem (other than needing new front and rear brakes) was the brake booster pump and they told me that it would cost $1800 to replace, so that's when I decided to take the car elsewhere. I'm in Bloomington, Indiana and the place where it's currently sitting is Micro Motors, who told me they work on Priuses but seem about to tell me that they can't work on this particular issue. Should I just take the car to a place that specializes in brakes, or is there a good way for me to find other independent general repair places that work on Prii?
  2. vskid3
    vskid3 Active Member
    773
    228
  3. jmelton
    jmelton New Member
    2001 Prius
    Not sure I want to risk driving 2 hours on gimpy brakes. But thanks for the tip, I will at least call them and see if there's anyone close by they would recommend.
  4. Patrick Wong
    18,210
    6,517
    I believe that autobeyours specializes in 2G Prius so they may not be interested in working on Classic Prius.
    Which warning lights appear on the dashboard?
    If the brake actuator assembly (what you call the booster pump) needs to be replaced, one possible alternative is to purchase a used unit and have that installed (maybe by your dealer.)
    I would not trust Prius brake service to an independent that does not specialize in Toyota hybrid service.
  5. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    If the brake actuator and/or master cylinder is bad an experienced hybrid shop should do it, since you have to remove the inverter first and be familiar with Techstream etc to reset everything once it's installed. I've had customers drive from hundreds of miles away to have it done since the dealer wants $$$. Pmail if you need good used parts and can find a local shop willing to tackle it.
    yotatoter likes this.
  6. jmelton
    jmelton New Member
    2001 Prius
    The "brake" and "ABS" lights came on once, but not otherwise.
    My impression from Googling was that if the actuator assembly/booster pump was bad that it would be difficult to press down on the brakes, which is not the case. If on the other hand the symptom is that it's commonly too easy to press the pedal down and it doesn't do anything until it's pressed down pretty far (or unless it's pumped), that's more likely the master cylinder. Is this correct?
  7. Patrick Wong
    18,210
    6,517
    I actually think that part of your car's problem might be air in the hydraulic brake lines. If the warning lights are not on, maybe you might start by having the brake fluid flushed, and then see how the brakes behave.
    If the brake actuator assembly is bad, then the motor will be running more than normal in an effort to maintain proper hydraulic pressure. I haven't seen reports of a failed master cylinder but have seen several reports of failed brake actuators.
  8. jmelton
    jmelton New Member
    2001 Prius
    Thanks for the info.! I finally found a shop here in town (Bloomington, IN) that is trained and experienced at working on Priuses (Prii?), Worldwide Automotive. They are indeed flushing the brake fluid to start with to see if the problem persists.
    The warning lights did come on and stay on for a little while yesterday when I just pressed the pedal almost all the way down rather than pumping it once to make the brakes engage, but then they went off and have not come back on.
    A major concern: If it isn't just a problem in the brake lines but indeed is the actuator, the guy told me the repair would be about $3000. That was more than the Toyota dealership quoted me to replace the "brake booster pump" which I gather is the same thing. Of course the reason why his estimate was so high was he was quoting me what it would cost with a new part; not sure why he would expect someone who only spent $4000 for a car to pay over $2000 for one part, but I insisted that if that repair was needed, we were going to go with a used part. Whoever can help me with a source for a quality used part, assuming this is needed, I'd appreciate the advice.
  9. ChapmanF
    18,996
    They're not the same thing. The booster pump is mounted under the cowl near the starboard side of the car, sort of below where the brake fluid reservoir is. It's what makes the hmmmmmmmmmmmmmmmmm-CLICK sound you hear when first starting the car, or after braking several times, as it pumps pressure back up. The actuator is a bigger box Medusa-like with brake lines, also mounted under the cowl, but more centrally. It's got a mess of valves under control of the ABS ECU, able to raise, sustain, or release brake pressure on each of the different output lines.
    Have you collected the trouble codes from the ABS ECU yet? If you don't have a suitable scanner like Techstream, you can also do it with a wire jumper and counting blinks of the ABS light.
    -Chap
  10. jmelton
    jmelton New Member
    2001 Prius
    Well, back to square 1 as far as finding a place that will repair my car. The place I took it, Worldwide Automotive, says (consistent with what the local Toyota dealer told me) that the brake booster pump needs to be replaced, and told me that the repair would be $2200, with about $1400 being for the part. They REFUSE to install a used part. There's no way I can afford this repair bill, so back to the drawing board finding a place that will service my car competently for a reasonable cost.
