Brake Shoe Hold Down Spring Driver Tool Recommendations
Discussion in 'Generation 1 Prius Discussion' started by Timester, Apr 25, 2018.
  1. Timester
    Timester New Member
    DTW
    2003 Prius
    Can anyone recommend a Brake Shoe Hold Down Spring Driver Tool ?
    Obviously, I'm not crazy about blindly ordering SST 09718-00010.
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    You can get them at most auto parts stores. Probly Harbor freight too. I never use them tho, I grab onto the spring retainer top with a vice grips, push in in to compress the spring, and give it a twist.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
  4. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Will try to keep this somewhat on topic and related.
    Is there a proper tool for the high tension spring that holds the two (2) shoes together?
    Been using a pair of vise-grips when available.
    Raytheeagle likes this.
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    The Repair Manual (available by subscription to techinfo.toyota.com) says to use SST 09703-30011, the Brake Shoe Return Spring Tool Set, sold here for $35.65:
    https://toyota.service-solutions.com/en-US/Pages/ItemDetail.aspx?itemVID=131982
    According to the Component Parts chapter (PDF) of the 2013 Special Service Tool List book, page 35, the set consists of the Bar, 09703-03010, and the Wrench, 09703-03020, not sold separately in the U.S.; I believe the third item in the illustration is a case.
    SFO likes this.
