Brake size for SE and XSE
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Mithrandir, Sep 10, 2024.
  1. Mithrandir
    Mithrandir Junior Member
    Ottawa
    2024 Prius Prime
    XSE
    Hello,
    I want to install winter tires on rims. The XSE has a 19 in diameter wheel. I want to go to a 17 wheel. I want to confirm if the brakes are the same size for the SE and XSE model. I am buying aftermarket rims and want to make sure there are no issues. I have checked all dimensions but I don't know about the brake size.
    Thank you.
  2. Mendel Leisk
    42,380
    Almost certainly there are no differences in the brake dimensions.
  3. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Brake sizes don't vary by trim - there should be no problem fitting 17" wheels to the higher trims due to brakes.
    There is a shock absorber difference between the trims - presumably some tuning for the different tyre profiles. So maybe a 19" car with 17" wheels might be a bit softer than a car originally intended for 17"?
    The PHEV does have bigger front brake rotors than the HEV.
  4. Xse
    Xse Member
    76
    34
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    toyota installed my tire choice of snows tires on steel rims (225/55 r 17 xl
    17” rims no problem over the brake rotors
