Brake vibration and whining noise
Discussion in 'Gen 2 Prius Main Forum' started by Zeebaba, Mar 12, 2020.
  1. Zeebaba
    Zeebaba New Member
    Uk
    Active
    Hi pls help ..I have a 2008 prius 1.5 ..when I apply the break there is a whining grinding noise and feel vibration on driver side. There is no noise when I break in natural..I have changed the pads discs and wheel bearing and also the drive shaft..the noise was there with the old pads and discs too ..when I bought the car i was told as it has been parked up the noise shall disappear..I also appears this car has had the gear box changed. What can be causing this noise and vibration?
    49,567
    sounds like the transaxle. any trouble lights?
    Zeebaba likes this.
  3. Zeebaba
    Zeebaba New Member
    Uk
    Active
    No lights at all..shall give that a try
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Have you checked or changed transaxle fluid? If fluid is low, bad, or magnet has big chunks in it that would be a hint that transaxle could be bad.
    Also might be good to check that passenger side drive shaft is good.
    Zeebaba likes this.
