Brake vibration, not rotors.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Breadman03, May 13, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    You're welcome. .009" is way too much runout.
    For measuring runout, I use 5 conical washers under the lug nuts. Then I install the lug nuts using an 80 ft-lb torque stick. Here is a short video clip that I made:
  2. ChapmanF
    19,038
    +1. The upper limit in the manual is about 0.002".
    If you didn't happen to mark which way the rotor was on the hub, or if a piece of grot got in there, you can sometimes see a crazy runout like 0.009" and get it back down under 0.002" just by trying the four other possible positions of the rotor on the hub. Doesn't cost anything.
    The Critic and Mendel Leisk like this.
