Brake warning lamp, and thumping
Discussion in 'Gen 2 Prius Technical Discussion' started by TWOPrius, Jan 13, 2017.
  1. TWOPrius
    TWOPrius Junior Member
    51
    Tampa
    Gen2. 08 prius, 120k. No codes. Scanning , turned off light. Did not clear. I need to locate vac pump.
    49,433
    any braking issues?
  3. TWOPrius
    51
    Tampa
    None yet. Think noise is brake accumulator. Could be internal hydraulic . How about rear brakes ( drum) need adjusting ?
    49,433
    not sure, might be self adjusting. if i lived in tampa, i'd swing by tampa hybrids and chat with them. todd is a good guy and a member here. even if you diy, he is very helpful.
    jerrymildred likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    If it's the brake pump, Toyota extended the warranty, but they won't replace it for free unless it throws a code. And it's REALLY expensive, so I hope it's something else. But it's interesting that you have a warning light and no code. I didn't know that could happen.
    And Bisco is absolutely right about Tampa Hybrids. Todd knows practically everything and they do just about everything except alignment, oil change, or tires. In fact, I was just over there today.
  6. TWOPrius
    51
    Tampa
    Yes i have been there nice gent. Im a former Toyota Mazda tech. Have the Toyota laptop software. No codes.
    bisco and jerrymildred like this.
  7. TWOPrius
    51
    Tampa
    On my last oil change they wanted to adjust the rear brakes I said they're self-adjusting he said sometimes, that was killed at Tampa Bay with those service advisor guy
  8. TWOPrius
    51
    Tampa
    jerrymildred and bisco like this.
  9. TWOPrius
    51
    Tampa
    Saw Todd. Going to see if Toyota of Tampa Bay will do the extended, campaign repair
  10. TWOPrius
    51
    Tampa
    Toyota doing extended replacement. Cant ask for more 123.000 miles. 08. Must have code as discussed.. Spoiled , waiting to get my most loyal friend back!
  11. jerrymildred
    11,508
    14,110
    Tampa, FL
    That's great!
  12. TWOPrius
    51
    Tampa
    Yes it is. Thanks to TampaHybrids com for the advice. Todd is a strait shooter. From keys Traction Battery. You cant get better. Toyota being smart to support the brand.
