Brake warning lights, codes C1256 + C1391
Discussion in 'Gen 2 Prius Main Forum' started by WhatNext, Aug 7, 2020.
  1. WhatNext
    WhatNext Junior Member
    17
    Upstate New York
    Hi there... it’s been about 3.5 years since I bought my 1995 Prius from a private seller for $4000 and then needed to immediately replace the hybrid battery for about $2000 more. The odometer’s up to about 144,500 miles now and I haven’t had any potentially expensive problems to deal with in that time. Until now.
    I was warned that this was coming... my independent hybrid mechanic told me a couple of months ago that the ABS pump was pumping way too often, so there was a leak in the unit and it was eventually going to trigger warning lights on the dash. That happened a couple of days ago and yesterday my mechanic at Pinpoint Auto Repair gave me the codes he pulled, confirming that the brake pump was the culprit. He tells me that in some unspecified amount of time, I’ll lose power assistance to the brakes if I keep driving my car in its current condition. I saw someone in a different thread here on PC say that this would probably happen in one or two days after warning lights lit up. So that’s one reason I’m posting about this, to get an answer for that question... is failure of the power brakes just a day or two away at this point? Because my mechanic tells me that he’s booked pretty solidly and wouldn’t have the booking free for the 6.5 hours or so needed to do the work until a little over a couple of weeks from now. He also said that if the power assistance on the brakes does fail, I should park it immediately, have it towed to his shop and he’ll make the time to make that repair happen much sooner. Naturally, I’m not so eager to risk a serious accident due to brake failure for the next two weeks, so I’m checking in with people who know better than me how long I can or should risk driving this car at all for that time without a replacement for the brake pump.
    And then there’s the matter of what replacement to get. A new ABS pump from Toyota seems to cost around $1700 with a three year warranty... with labor and tax, my repair bill would come to about $2450. My mechanic offered the option of putting in a used ABS pump for a total of about $700... with no real guarantee of how much life is in it, maybe it’ll come with a one year warranty. I saw elsewhere on PC the option of a Dorman remanufactured ABS pump for $825 with a lifetime warranty, which sounded like a decent middle of the road solution on the surface. My mechanic pointed to a page on summitracing.com where this part was being sold (part #587-765) with two reviews, both of them one star, that made him leery of that option. But I think I saw that somebody here on PC got a Dorman ABS pump for their own Prius and it worked out fine. So I’m wondering what other people who know better than I do about Prii and Dorman ABS pumps think about which option I should take here. Lifetime warranty gets much less appealing if the part keeps generating 6.5 hours of labor charges to swap out for another Dorman part.
    And speaking of Dorman replacement parts, it just so happens that when I replaced that dead hybrid battery about 3.5 years ago, I replaced it with a Dorman battery pack. When I bought it back then, it had a three year warranty on it. And so far I’ve had to take my Prius to my mechanic to swap out a failed Dorman hybrid battery for a new one under warranty every year. The one that’s in my Prius now has lasted longer into the year than the previous ones have, and I’m hoping that it can end up lasting at least until 2020 is over. Because the 3 year warranty on the Dorman battery is over and they’ve changed to a 1year warranty for some odd and mysterious reason. And I’m pretty okay with making one repair to a major component in this car this year, but a bit more leery about fixing two of those for a total of more than the value of the 2005 car with 144,500 miles on it. On the other hand, now that the price of Toyota hybrid batteries have significantly dropped in price from where they were 3.5 years ago down to $2200 or so now... maybe my odds are better at ending up with a reliable vehicle with some good years left in it if I bite the bullet and replace both of those parts with OEM from Toyota instead of jumping ship and putting that money into a different car? It seems to be in otherwise good shape inside and outside from what I can see and from what my hybrid mechanic tells me. So again, I’m interested in what other people more knowledgeable in the ways of the Gen 2 Prius than I am would do in my shoes at this point.
    Last “what would you do” question... should I bring my Prius to the local dealership and have them put the OEM Toyota ABS pump in? My hybrid mechanic has been very good to me these 3.5 years and I want to give him my business, but I’m not so sure I want to either put myself, my passengers and my car at risk for a couple of weeks or be without a car for that time. I’m thinking it could easily be worth my time and money to take my Prius to them, fork over $100 for their diagnostics to tell me what I already know so I can get an estimate on time and money needed for them to fix the brake pump. I’m not sure how much more money than $2500 that’d be likely to cost me... I’m sure they’d be more than happy to let me know if they have my car and $100. But maybe somebody here who knows more than I do can tell me first.
    So that’s pretty much it. What would you do? I’m sure many of you can and would put a bunch of money saving DIY magic into a car like this, but I’m not that guy. The most I’ve ever done myself on a car that I’ve owned is change a headlight and change a speed sensor. So what do you think I should do?
  2. ChapmanF
    18,911
    The only money-saving DIY magic that's probably available here is to replace the unit at home rather than paying for somebody else's labor to do it. Bit of an involved job though.
    As far as I know, Dorman is a reasonably respectable source for remanufactured parts. I think they are at a disadvantage with traction batteries because there isn't really much they can do other than try to match up 28 elderly modules and make a battery, and the modules just deteriorate over time.
    I wouldn't assume that any elevated failure rate they have in traction batteries would necessarily spill into their remanufacturing of other, more traditional, electromechanical stuff.
    But I haven't read what those 1-star reviews actually said....
  3. WhatNext
    17
    Upstate New York
    A954534B-074C-4E9F-B13E-A731BA488B8A.png Here they are...
  4. WhatNext
    17
    Upstate New York
    “Totally lost my confidence in these so called refurbished pumps.”. That’s the rest of that last review, for whatever it may be worth. Those are the only reviews for that part that I’ve been able to find so far anywhere. Even Amazon comes up empty for reviews for that part of any kind.
  5. bisco
    52,730
    i would get a new one, brakes are important
  6. ChapmanF
    18,911
    Does the Summit storefront say how many of those they sold? Those look like the only two reviews, both from people who had immediate problems right after installation. Sometimes people who don't have problems move on to their next project without taking the time to leave a review.
    I would be interested in whether that was two out of two purchasers, or two out of 2000 purchasers.
    I would be surprised if they shipped a lot of units that could be that faulty right out of the box, but depending on how many purchasers you've had, you might be able to find two who could manage to botch an install and blame the part.
    I don't know one way or the other. I don't work for Dorman and I've never bought one of these from them.
  7. WhatNext
    17
    Upstate New York
    That's information that I would *really* like to have too... two one star reviews, spaced about nine months apart, and how many parts had no problems before or after or in between? As far as I can see so far, that information is nowhere to be found on summitracing.com . And I can totally see how anybody who had a bad experience like those two unsatisfied customers would be *highly* motivated to let the world know what they think, but maybe not so much for whatever satisfied customers there may or may not have been.
  8. WhatNext
    17
    Upstate New York
    Quick update... I have an appointment with the local Toyota dealership Monday evening to spend $100 to see how soon they could fix the brake pump and how much they'd charge me for it.
    In the meantime, I'll repeat one of my earlier and more time-sensitive questions... how long can I drive this car with the brake pump putting warning lights on the dash before it's too risky and dangerous? Can I reasonably expect to get where I'm going safely if I make the 10 mile drive to work on Monday before dropping off my Prius at the dealership on the way home? I could take the cautious step of dropping off my car at the dealership today and planning to bus it to work on Monday. I'm just not sure how much I'm putting myself, my car and others at risk by driving it anywhere until either the dealership or my hybrid mechanic can get that brake pump fixed.
  9. ChapmanF
    18,911
    The typical way those codes should go is you will hear a long high-pitched beep alarm if the pressure drops too low to give you assist, and without assist, you will have to press a lot harder on the pedal, but that works. You will not have ABS or stability control; it will be like driving Grandpa's car, but with really stiff brakes.
    Much more rarely, somebody shows up here and reports a different kind of failure, the floored-pedal-no-stoppie kind, which is understandably terrifying, but that seems to be an entirely different failure mode with probably an entirely different cause.
    None of this is to say I would wait any longer than necessary to get the work done.
    You should make an allowance here for my experience being mostly Gen 1 and Gen 3, which have quite similar braking systems; Gen 2 (yours) was the odd one, and has some significant differences.
    WhatNext likes this.
  10. WhatNext
    17
    Upstate New York
    I actually heard that beep alarm coming from the ABS pump after my mechanic warned me about the unit but before it put warnings on the dash... I was in a parking lot, turned the car on and I heard that steady high-pitched tone and had no idea what it was. I turned the car off then turned it back on and the warning tone was gone. I sent a text about that sound to my hybrid mechanic and he told me it came from the ABS pump, another sign of impending failure. So I'm pretty sure I'll recognize that sound if I hear it again. :)
  11. ChapmanF
    18,911
    Well, pedantically speaking, it comes from a beeper under the dash. The pump is under the hood, and sounds like a pump. :)
    The computer running the brakes turns on the beeper when it is trying to tell you "hey, I haven't got enough pressure to give you good brake assist, be ready to press the pedal harder."
  12. WhatNext
    17
    Upstate New York
    Seems like that’s the kind of thing where if that’s what the brake pump is trying to say, shouldn’t it say that a little more clearly? I mean, that shrieky tone really gets your attention and all, but shouldn’t it send a clear message along with that warning tone, like turning on a warning light on the dashboard or putting a message on the center console that says “power brake assistance failure”? Something to let you know *why* that warning tone is sounding off at you? Just a crazy thought.
    Another question that comes to mind... if the power assistance stops functioning on the brake pedal, will the emergency brake still work? My guess is that would still work, but I’m not 100% sure so I’m asking.
  13. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    One thing you might try is to price shop the part at Online Toyota Parts Store that some dealers do. A good starting point is Toyota Parts Center Online who can then also direct you to dealers local to you. Even though the list price is something like $1,700, some of these online dealers list it at ~$1,150 and some PriusChatters have successfully got their local dealer to price match on the part. If they won't price match you can always buy the part and have your local mechanic fit it.
    Just a thought and you have nothing to loose in trying.
  14. ChapmanF
    18,911
    Yeah, I'm not sure why it's exactly that way. I'm pretty sure it doesn't sound the alarm without also lighting at least one of the brake-related dash lights, and the owner's manual (which everyone carefully reads) does say if you get these lights with this beep, be ready for difficult braking and don't drive the car. They probably figure more detail than that would be too esoteric for average drivers.
    I also think commercial rigs, with air brakes, use pretty much the exact same sound when the air pressure is low. My parents had a big ol' RV for a while, and when you started it, that was the sound, until the air was pumped up.
    So drivers with CDLs probably all hear that sound and immediately guess what it means.
    Maybe Toyota got a bunch of designers in a room, and half of them thought Prius drivers would all feel you're going over their heads if you talked about "brake pressure", and the other half thought Prius drivers would all have CDLs.
    The parking brake works mechanically by pulling on a steel cable, independently of all that other stuff, so yes, you'll still be able to park.
    And while it will be possible to use the parking brake in an emergency (heck, in an emergency you try whatever you've got, and the parking brake is something you've got), you have to be pretty careful, because it isn't designed for slowing a car from driving speeds, and it only acts on the rear wheels, which have the least ability to hold traction while braking, and the ratchet pedal doesn't let you control your pressure very well; if you overdo it, you have to remember (mid-emergency) that you need to push-release it before you can back off.
    On occasions when I've used the parking brake to slow the car while driving, I've deliberately double-pushed it right at the start, so the ratchet is already released, and I can modulate the pedal normally. (You just have to watch you don't let it all the way back up, or the ratchet resets.) I spent some time practicing that, hoping to make it automatic in case I ever need it for real.
    So far, I never have needed it for real, and those practices are my only times ever doing it.
  15. WhatNext
    17
    Upstate New York
    Thanks for the help and the info, guys... :)
    I brought my Prius to the Toyota dealership two days ago, they gave it back to me yesterday. I told them that my independent hybrid mechanic told me that the brake warning lights were coming from the ABS actuator, showed them my $2500 estimate for repairs from him, told them he said he couldn’t do the job for a couple of weeks... let me know how much time and money it’ll take for you guys at the dealership to do it, and I’ll decide which way to go with that. The estimate I got from the dealership yesterday says $2534 for the actuator fix and $180 to bleed brakes and replace brake fluid... I can bring the car back to them next week Monday or Tuesday for the repair.
    I checked Toyota Parts Center Online as dolj recommended and I found a few Toyota dealerships within 200 miles selling ABS actuators for around $1200. The local dealership told me to bring the Prius back to them next week because they were ordering the part, so I may have an opportunity here. Do I go back to the service department and show them the cheaper prices on my phone and ask them to order from one of those Toyota dealerships and pass the savings along to me? Do I ask them to use my own part and have one of those cheaper ABS actuators shipped to me? For all I know, they may already have the part ordered and on the way to them as I’m typing this. I’m guessing that I still have the option of cancelling the repair appointment, having the cheaper Toyota OEM part shipped either to me or my hybrid mechanic and waiting another week for him to do the repair for me.
    One thing that confused me a little was that I was searching for a part number that I saw earlier on PC for the ABS actuator, #44500-47050. I found it listed on Toyota Parts Center Online under #44500-47091. I’m guessing this is a newer version of the same part? Little bit confusing for a non-expert like me, perhaps deliberately so. My main concern is trying to avoid getting a replacement part installed that has the same defect that’s causing the original to fail now... as long as either of those part numbers was made to correct that defect in the original unit, I’m okay with that.
  16. dolj
    dolj Senior Member
    8,631
    4,385
    Your strongest opportunity to negotiate that would have been before you accepted their offer. So, you should have researched that before going to meet with them and then gone into the discussion forearmed. Now that you have waited, it probably is too late, but if you don't ask you won't get.
    Yes, that is basically it. The 5 numbers before are the main part number and the 5 numbers after are the version (or sometimes variation, LH and RH e. g of the same part) the last 1 or 2 digits usually increment for improved versions.
  17. WhatNext
    17
    Upstate New York
    Update on this brake repair:
    Thanks to dolj’s advice, I was able to get a $1700 ABS actuator shipped to me from Mars, PA for $1300. So after not going back to my local Toyota dealership to do the repair job and waiting for my independent hybrid mechanic to have a day free in his busy schedule, $600 in labor charges later and my brakes have been fixed for a total of $1900 or so.
    Thank you to the helpful advice givers at PriusChat.com and the Martians living in Pennsylvania for all of the help with my new ABS actuator!
    dolj likes this.
  18. ChapmanF
    18,911
    Careful - your brakes might be optimized now for 1/3 Earth gravity.
    Data Daedalus and WhatNext like this.
  19. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    iPhone 6s +
