Brakes already!?!?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Prigirl, Jul 8, 2019.
  1. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    My original pads, drums, and rotors lasted for 300K miles on my 2nd gen prius.
  2. Mendel Leisk
    42,264
    Don't conflate pad/shoe longevity with the need for periodic brake maintenance though. Toyota USA says tri-yearly or 30K miles, do a full inspection, clean, relube various points, check pad/drum/rotor/drum measurements against spec.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I think the key to this particular case is that this is a Gen 4, which has significant changes since Gen 2. And TOYOTA did a full refurbishment without quibbling, which is almost unheard-of, which sort of indicates that they might be aware of some material issues with those particular parts on that particular car - maybe tracked it back by VIN?
    52,776
    and don't compare california to ohio
  5. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Yeah they don’t have rolling brownouts there:unsure:.
    ETP and bisco like this.
  6. bisco
    52,776
    a small price to pay for living in paradise my friend :)
    ETP, krmcg and Raytheeagle like this.
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    At least I wasn’t one of the 800,000 last night:).
    But still parked the cars outside rather than have to deal with the manual garage door shuffle(y).
  8. bisco
    52,776
    time for a power wall?
    Raytheeagle likes this.
  9. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    When I asked last April about that with the Solar City rep when we put the solar panels up, he laughed at the suggestion :cool:.
    Said they were focused on cars:whistle:.
    I took that as queue and went with Sun Power(y).
  10. bisco
    52,776
    moral of the story: don't get your bev from sun power
  11. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Too many people are continually comparing pac8 and big10
    bisco and krmcg like this.
  12. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    I’ve had three Prius now, and never manage to wear out breaks. But indications on the first two were that they would last 200 K. A few years ago I encouraged my sister to buy a Prius. She bought a brand new 2014, and managed to wear the brakes out in about 40 K she routinely stomped on the brakes, stopped 100 yards behind other traffic at signals, and commented many times that she just couldn’t get the feel of driving the car. Some people never get it, driving cars with regenerative braking. Happily she now drives a Mazda CX 5 Oh well.
    ETP likes this.
  13. Clifford Bradford
    Clifford Bradford Junior Member
    16
    Cincinnati
    Dealers are always "conservative" on brakes. They'll tell you to change them when you have 25% left which is a lot. I'd recommend that you ask for the actual numbers. My experience is Midas will give you the actual numbers i.e. your pads/discs are x.xxx inches thick and the minimum is y.yyy inches so you have 0.zzz inches left.
    krmcg likes this.
  14. Mendel Leisk
    42,264
    If I've taken the time to pull off the calipers and I'm looking at only 2, even 3 mm's, I'm gonna change them. I don't want that pending job on my mind.
    Also, and I'm a broken record on this: don't conflate pad thickness with the need for brake service. Toyota's recommended three years or 30K miles interval is reasonable.
  15. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    I also call BS on the dealerships story. It seems to me like they are trying to cover for their prior scam after corporate got involved.
    if the rotors were severely rusted you would be able to see that just by looking at them while the wheels were still on. Rotors frequently get a little rusty and it is quickly and almost instantaneously removed the next time you apply the brake. Unless you were letting this sit for an extended period on a beach I highly doubt they are being truthful.
    I would like to see real analysis, but I suspect that there isn’t one and they never contacted you again after this.
  16. ChapmanF
    18,957
    My Gen 1 front rotors developed really wide rust bands, only on the inboard side, scarcely visible without disassembly. Left only a skinny path down the middle where the pads were touching.
    Light surface rust gets easily scoured off by the pads in normal use, but somehow once these ridges get started (however that initially happens) they are tougher than that, and they carve off the edges of the pads, so there is no longer anything to scour them, and they grow and grow.
    I haven't seen the OP's rotors, but I know at least that is a thing that can happen. It has only just now started on the rear rotors of my Gen 3 (at 150,000; at my previous inspection last spring there was no sign of it).
  17. vvillovv
    4,336
    1,518
    NY
    I've found doing pads and rotors can have worse results sometimes than leaving the factory installed components on for as long as the pads wear. Unless the new or turned rotors fit back onto knuckle and turn to spec the wobble of the rotor can burn through a set of pads really quick.
    If the OEM brakes have already been serviced that is another story, when considering replacing or servicing the calipers, pad and rotors.
  18. ChapmanF
    18,957
    The advice in the repair manual to try the rotor all five ways on the hub, measuring the runout each way, and pick the one with the smallest measurement, is not just a waste of time. I have definitely seen the runout measurement be well out of spec 4 ways out of 5, and suddenly nicely within spec for that one sweet position.
    Mendel Leisk and vvillovv like this.
  19. Mendel Leisk
    42,264
    It also notes to mark the rotor and a stud before removing the rotor, and reassemble the same orientation. That presumably applies when runout is within spec as-is.
    vvillovv likes this.
  20. JTEM
    JTEM Member
    59
    35
    Boston, MA
    Did you get a third opinion regarding the brake work? Any idea about the root cause for the premature brake work? Did you end up getting the work done?
    Thanks.
