Brakes going soft
Discussion in 'Prius v Technical Discussion' started by Wolfgang Langlois, Aug 10, 2023.
  1. Wolfgang Langlois
    Wolfgang Langlois Junior Member
    Hawaii
    2013 Prius v wagon
    2013 Prius V, 78 000 miles, the Brakes still working fine but I have to press the pedal all the way down when I start the car, then while driving the brakes pedal goes back to normal. Checking with Dr Prius OBD I get the code that the hybrid battery has to be replaced. After applying the erase error codes with Dr Prius the brakes work fine, but go back to being soft after a short time.
  2. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Pretty low miles for a bad Traction Battery. Does the brake pump run more than usual?
  3. Air_Boss
    Air_Boss Senior Member
    4,262
    1,197
    New Yawk
    Failing or leaking ABS pump/accumulator?
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,989
    Texas Hill Country
    Are you sure its a soft pedal versus poor braking? These cars are brake by wire so normal rules for direct hydraulic brakes don't apply.
    Dr Prius may not be reading brake codes. No warning lights like VSC, etc?
    I would take it to a dealer for diagnosis given brakes are important and gen3 has issues with brake boosters.. Odds are a 2013 is beyond the ten year limit of this program but maybe...
  5. Wolfgang Langlois
    Hawaii
    2013 Prius v wagon
    Thanks for all this great advice, especially the ten year program. I will take it to the dealer to get error codes diagnosed.
    I need to add all the
    Lit up symbols:
    Brake
    Brake system warning light
    ABS warning light
    Slippery road Symbol
    Tim Jones likes this.
  6. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  7. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    If not covered you may want to decline their diagnoses.... and get techstream on amazon.....
    But I can see a dealer diagnoses might be better for you....... use caution........$$$$$
