Brakes reading
Discussion in 'Gen 3 Prius Main Forum' started by mnsweeps, Apr 16, 2013.
  1. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    I have about 21000 miles on 2012 Prius and did the 20k service at local dealer. They marked the brakes as FRONT BRAKES 8.0MM__ REAR BRAKES__8.0MM____ ? What does that mean ?
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    It means your brakes show only about 10% wear or less.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It also means nice, even wear. Well done.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I believe the spec for new brakes is 9.0 MM so that should give you a perspective of the low wear rate. Prius brake pads last much longer than non-hybrid cars due to the regen braking feature.
  5. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    Thanks guys. Thats good to know. I just bought it last month and was wondering the guy who owned it had driven quite a lot for less than one year... 19k miles in 10 months ..Must be all freeway so less use of brakes :)
