Brakes slam/thumping after hubs replaced.
Discussion in 'Gen 2 Prius Main Forum' started by kenoarto, May 25, 2024.
  1. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Front hubs/bearings replaced by Car-x. The usual 7mph transition slip became an inreasing, very noticeable clunk/thump/slam/squeak. Cleaned rear brakes. Replace one brake line. Thump is less but stii very wrong. Ideas?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    If brake operation was "normal" before Car-x performed work, why not take it back there?
    Drive the car at 30 or so. Shift to neutral then apply the brakes. (this disables regenerative braking so you only use the hydraulic friction brakes). How do the brakes sound or feel?
  3. Mendel Leisk
    42,246
    Sounds coming from front, back, hard to tell? You've looked all the calipers over thoroughly?
    First thought is someone forgot (or didn't torque) one of the caliper bolts, either the ones going into the slide pins, or the mounting bracket bolts.
    Just for giggles try raising the rear and see how free the wheels spin? (see link in signature; on a phone turn it landscape to see signatures)
    kenoarto likes this.
  4. kenoarto
    398
    Chicago, IL
    Ya. Brought it back to the shop 3 times! Charged me another $270 to replace a leaking brake line that they somehow missed the first 2 times???). I know exactly what the smooth transistion release/slip at 7 mph should feel like. This is a soft thunk/bang.
  5. kenoarto
    398
    Chicago, IL
    Sounds like rear… but not sure. Will have calipers, slide pins and bolt torque triple checked.
    Please explain"signatures".
  6. kenoarto
    398
    Chicago, IL
    Found your signature links. Thx!
