BRAKES SQUEAKING
Discussion in 'Gen 5 Prius Main Forum' started by STcrew11, Jan 26, 2024.
  1. Mendel Leisk
    42,248
    Every time I wash the car and it sits for a few days, next drive it’s noisy for the first block or two.
    STcrew11 likes this.
  2. Kenny94945
    Kenny94945 Active Member
    862
    438
    Sausalito
    2016 Prius v wagon
    Yeah, I wrote too much :)
    Here in Calif, my '17 does not have this noise/ squeak issue, even after a car wash, yet I brake hard LOL.
    Yet, many of our co-members write about brake noise so, well, I wrote too much.
    Perhaps, our co-members are correct that moisture/ winter/ snow is the issue and there is no cure.
    I still recommend the 75 to 45 mph hard braking as a fix, for squeaky brake noises, even if temporary.
    Have a great day everyone :)
  3. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I'm in the CO mtns. No squeaking from mine. Been thru plenty of snow/rain
  4. Trollbait
    12,800
    It isn't the wetness directly, but moisture and lack of use for a spell.
    The rotors are made of iron. They get wet, don't immediately dry, then sit unused for a bit, and you'll get surface rust. Which makes the brakes noisy and grabby until all that rust is polished off by the pads.
  5. STcrew11
    STcrew11 New Member
    New York
    2023 Prius
    Limited AWD-e
    Thank you so much for your feedback.
    I also planning to remove the pad and clean it before replacing with a new pad. There is no sound from the other 3 wheels, but the sound is only coming from the driver side brake. I did cleaned it with brake cleaner, but always makes a noise when its wet.
    Here is little clip for my break squeaking sound.
    Gen 5 Prius BRAKES SQUEAKING - YouTube
    Gokhan likes this.
  6. Gokhan
    Gokhan Senior Member
    6,691
    2,651
    Paramount CA
    Yeah, that's not due to rust. Rust sounds like grinding. It is something else. Replace them and see what happens.
  7. Trollbait
    12,800
    I'd try cleaning and relubing the caliber pins and tracks the pads slide on before changing parts with a noise like that.
    Does the noise go away after a bit of driving? The pads and rotors themselves should dry off pretty quickly if there isn't water around to get back on them. If it lasts longer, that would point to the water getting elsewhere.
  8. STcrew11
    STcrew11 New Member
    New York
    2023 Prius
    Limited AWD-e
    When its dry, sound go away within 15-30min driving, but still there.
  9. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    That's most definitely not normal. I would get that to the dealer ASAP and have them fix it.
  10. Kenny94945
    862
    438
    Sausalito
    2016 Prius v wagon
    ST...
    I listened to the video... almost sounds like a meowing cat LOL.
    My take the sound is harmonics, vibrations, not a grind.
    It is only one wheel squeaking, yes?
    I would offer:
    1) Check the true-ness of the rotor.
    2) Check the brake pad backing surfaces (piston to pad) for wear.
    3) Lube your caliber pins and the pad edges where specified.
    4) Do some hard braking.
    That's your no cost repair.
    Since you say the noise returns after 15-30 minutes of driving, I think you are too easy on the braking.
    The pads are not even to the rotor causing a vibration.
    So, what would cause a brake vibration noise?
    Light braking on an uneven rotor is my number one guess.
    The noise could be caused by pad-to-rotor vibration, pad-to-caliper piston vibration, a loose caliper, and/or a loose rotor come to my mind.
    Your lowest cost repair would be:
    As I believe your plan is; to replace the pads.
    But I would also inspect for the need to replace that rotor too.
    Your highest cost repair would be:
    1) Replace the rotor.
    2) Ensure the hub surface where the rotor mounts is level/pristine/ clean.
    3) Replace the pads ... and replace the other side too (as a set).
    4) "Blue Print" the pads.
    5) Ensure your caliper mount/ torque is secure, clean, and correct.
    6) Since my theory is harmonic vibration, check the caliper pistons for "levelness" and cleanliness.
    7) Bleed your brake fluid to make sure there is no "compressing" air or debris in the line to that squeaky wheel.
    8) Thoroughly clean all related components before assembly.
    Without "being there" above labor has a goal to once and for all stop this noise and find the cause.
    If not DIYing, I could see 4 hours shop time plus parts.
    OEM rotors, pads, caliber, fluid, Techstream access, machine shop outsourcing, environment fees, and sales taxes.
    In closing, many cars squeak their brakes and I still think many Prius owners are too "easy" on the brake pedal.
    But I may be wrong in my theories, and you, in particular, may have a Prius mechanic problem.
    It seems our co-members are "split" on pad moisture absorption, rotor rust, and/or environmental temperatures being a cause of a squeak or if a squeak is just a normality.
    Do some hard braking remains my best advice :)
    Yes, it is my fun to write, add to this thread and see if my internet-deducing mechanic skills can cure your issue.
    At the very least, I am stirring the pot LOL.
    Let us all know your findings and success :)
  11. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Not sure what the high cost would since OP has driven only 700 miles. A trip to the dealer would solve the problem since it's under warranty.
  12. STcrew11
    STcrew11 New Member
    New York
    2023 Prius
    Limited AWD-e
    I went to the dealer 3 times for same issues, but since brake operated normally, there is nothing they can do. I think I'll have to go to another dealer.
  13. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    If your dealer heard that noise and said they can't do anything about, it most definitely is time to find another dealer who is more competent. You may want to try and bend the ear of the general manager of the dealership and have them listen. I would also send Toyota Corporate an email with the video of the noise. Pretty certain Toyota doesn't want one of their new cars driving around making that gawd-aweful sound.
    Mendel Leisk and STcrew11 like this.
  14. STcrew11
    STcrew11 New Member
    New York
    2023 Prius
    Limited AWD-e
    Thank you for you feedback. I just wrote email to Toyota. I'm planning on going to a different dealer, and I'll update when they fix it.
    HacksawMark likes this.
