Braking while in neutral
Discussion in 'Gen 2 Prius Technical Discussion' started by georgekessel, Oct 9, 2007.
  1. georgekessel
    georgekessel Member
    182
    I couldn't find the answer to this in my forum search.
    If you are in neutral but going 40mph, and you hit the brakes does that only active friction brakes or does some regeneration occur?
    I have a tendency (as do many) to coast down slight hills in neutral.
    I always shift back to D before hitting the brakes to cause regeneration but thought I'd ask if maybe I don't have to...
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    Regeneration is not possible in Neutral...pure friction braking.
  3. D0li0
    D0li0 New Member
    118
    Seattle, Wa
    <div class='quotetop'>QUOTE(Ecojosh @ Oct 9 2007, 03:16 PM) [snapback]523323[/snapback]</div>
    That's probably not a good idea, if the ICE is not running as you begin to go faster than 40mph one of the MotorGenerators could overspeed. If the ICE is running you should be alright, but why exactly do you use neutral?
    L8r
    Ryan
  4. Tideland Prius
    16,206
    You'll use the friction brakes. It's a good way to clean them!
    Why not feather it? It's like neutral except that if you need to brake, you can simply lift off and brake without shifting.
    <div class='quotetop'>QUOTE(D0li0 @ Oct 9 2007, 06:13 PM) [snapback]523368[/snapback]</div>
    The engine will spin even in neutral, no worries.
  5. georgekessel
    georgekessel Member
    182
    It's very hilly here and my 06 doesn't like being feathered. Sometimes she'll really fight with me about that and outright refuse to go 'neutral'.
    My friend's 05 is easier to feather than mine, do not know why.
    So, as I coast I find it a lot easier to just switch to neutral (it's way easier and more relaxing then trying to hold my foot at just the right spot, and as I said sometimes she just refuses to to....)
  6. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    You should never coast for any distance in neutral. Its like flat-towing a car with automatic transmission, which is never recommended. I guess you have your reasons, but nobody that I can think of would say coasting at speed is a good idea with an automatic, or any car for that matter. Isn't 50 mpgs good enough for you?
  7. Bob64
    1,540
    92
    Virginia
    I heard, from FireEngineer (I think), that the prius consumes more power when gliding as opposed to neutral-gliding...
  8. efusco
    19,891
    1,193
    Nixa, MO
    <div class='quotetop'>QUOTE(subarutoo @ Oct 10 2007, 02:46 PM) [snapback]523754[/snapback]</div>
    Well..... It's really not like an automatic transmission in the Prius. Everything spins freely and is completely disengaged at the inverter. There's really not any risk of damage to the PSD or MGs unless you exceed 62mph with the ICE off.
    While there may well be good reasons not to do this the justification you gave is not amongst them.
    And NO, 50mpg is definately NOT good enough. I'm severely disappointed in any tank below 55 these days. YMMV. B)
  9. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    <div class='quotetop'>QUOTE(subarutoo @ Oct 10 2007, 03:46 PM) [snapback]523754[/snapback]</div>
    I agree with efusco. I think coasting is a good idea and 50's is not good enough for me. We finally got the previous tank in the 60's and currently are at 60.5.
    Two reasons I coast in N-- sometimes I want to give my foot a break from feathering to find the "no energy" zone. Second, on some hills I know I will be able to accelerate by coasting to a speed above 41 mph. If I am in D the ICE will come on at that point, if in N it will not.
    Happy coasting!
    PA P
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This is a small point, but it many locations it is illegal to coast in neutral. Make sure to shift back to D before you crash. :D
    Tom
  11. Tideland Prius
    16,206
    Ditto. 50 isn't enough any more lol. I haven't seen anything below 55mpg in 5 months. I'm sooo not looking forward to winter.
  12. PA Prius
    754
    241
    SE Pennsylvania
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 10 2007, 04:31 PM) [snapback]523804[/snapback]</div>
    Right, I suppose this is the one upside to global warming :( we had 93F here yesterday. And then there is that cheap set of 4 snow tires I couldn't pass up at $10. each. They killed my mileage last winter....
    PA P
