Brand new 12 volt battery not reaching 100% state of charge
Discussion in 'Gen 2 Prius Main Forum' started by GTW, Aug 7, 2018.
  1. Mendel Leisk
    41,469
    Either way.
    The jump point under the hood is more convenient I think. The CTEK's also come with a quick connect. I didn't bother with it for years, just used the alligator clips, but now our car often sits idle for a day or three, and I keep the charger hooked up more often than not, so I did wire the quick connect.
    As I've installed it (patched into the 12 volt positive lead at fuse box, and a grounded bolt) I still need to pop the hood, but the connection is very secure, and I can lower the hood loosely, not locked, on the cord. In a pinch I think I could lock it, but we're in a secure garage.
    GTW likes this.
  2. audiodave
    audiodave Active Member
    800
    272
    US
    I charge mine once or twice a week since the Prius system doesn't seem to want to charge it properly.
  3. Mendel Leisk
    41,469
    I think it will charge it sufficiently, IF you've got a regular commute, decent length. But retirees, lots of idle time, maybe not sufficient.
    In a way a charger is good for the environment, you don't feel that obligation to drive it daily.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Makes absolutely no difference.
    Whichever is most convenient.
  5. GTW
    GTW Junior Member
    55
    23
    Castroville
    Is it not ironic that a car with a sophisticated High Votage charging system, has minimal low-voltage charging?
    audiodave likes this.
  6. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Unless I become incapacitated, I try to drive daily, otherwise I get too bored. And I don't want to become a grumpy old homebound guy. :( But I only do about 25 daily miles. And maybe a short 50 mile higher speed freeway jaunt on the weekend. Is that enough? Or do I need to be looking at a Corolla...
    I'm learning that there are so many things different about this Prius. Should I just buy a new battery every 4 years? (play it safe.) When buying a new OEM 12V battery at the dealer, I wonder if they give it a charge before install.
    (No, I don't have a garage. Or a charger. Or a place to plug-in a charger. Or any tools. I'm on the third floor of a large treehouse)
    #26 Starship16, Aug 7, 2018
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I agree with Prius camper.You most likely bought a soft battery. We will never know because a simple voltage check done by you at time of purchase would have told the tale.
    Sometimes car batteries sit on there display rack a long time.
    When I bought my yellow top a few years ago after seeing so many story’s like yours here I brought my fluke dvm and had to go through 3 battery’s to find one that was charged,
    My bought new 07 keeps my battery at 12.6 volts sitting. Same voltage the stock battery measured sitting since birth.
    The stock battery is far superior imho than a yellow top.
    Do this simple test. With car off measure battery voltage at front jump point. Write that Down. With car off put headlights on high beam for 5 minutes and then measure again. My 4 year old yellowtop does not drop one volt in this test.
    GTW and George W like this.
  8. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Ps
    At 12.6 volts and trickled charge at 2 amp it takes forever to reach 13.8 volts like 2 days.
    It’s a long long way to tipperary from 12.6 to 13.8 trickle charging.
    My bought new in 07 never measured higher than 12.6 sitting with very healthy monthly maintence charges. That battery lasted 7.5 years so the car is doing something right.
    On the other hand My Crown Vic with a huge high quality battery lives at 13.2 sitting.
    #28 edthefox5, Aug 7, 2018
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Ah, not a yellow top equivalent but a yellow top, got it.
    The reason we and Toyota put a deep cell battery in the prius is that it's such a small weak battery, it goes ded in ten minutes if left in acc mode, and when it goes ded, simply trickle charge it and it's like new.
  10. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    If it goes dead in 10 minutes, then your battery is EOL (end of life). Replace it.
    I can run my car on ACC (just the radio, usually) for hours. But then again, I maintain my battery to ensure it does sit for any length of time discharged, as sitting discharged will kill it in no time.
    Incidentally, my 12 V holds 12.9 V 3 years down the track. It held 13.2 V when new.
    #30 dolj, Aug 8, 2018
  11. Mendel Leisk
    41,469
    EOL equals End Of Life?
  12. sam spade 2
    7,035
    2,803
    2017 Prius c
    No......because it has a minimal NEED for low voltage current.
  13. sam spade 2
    7,035
    2,803
    2017 Prius c
    Yes, an average of 25 miles per day is plenty.......IF THE CHARGING SYSTEM IS WORKING RIGHT.
    PLEASE HAVE IT TESTED. PLEASE. You seem to be ignoring that critical piece of advice.
    And the things that are different about a Prius are not really important to the average driver.
    It was designed so that you could get into it and JUST DRIVE IT, just like any other car.
    If something goes wrong, you get that fixed.......just like any other car.
    If you just DO that, you should feel much less stress.
    Starship16 likes this.
  14. Starship16
    1,348
    1,455
    Beach Christmas
    Thanks Sam.
    Just drive it.... :D
  15. GTW
    GTW Junior Member
    55
    23
    Castroville
    Yet there are Accessories that are ''warned' as discharging the battery if left unattended too.
  16. bisco
    51,955
    i don't know if it is ironic, but toyota may have a reason. the battery is so small, maybe faster charging would shorten the life.
  17. sam spade 2
    7,035
    2,803
    2017 Prius c
    None of the factory "accessories" draws a significant amount of current, if the vehicle is properly turned OFF.
    After-market accessories might be a whole different story.
  18. GTW
    GTW Junior Member
    55
    23
    Castroville
    Toyota included a smart key off switch under the steering wheel.
  19. sam spade 2
    7,035
    2,803
    2017 Prius c
    Are they still doing that on the new models ?
    I don't think my C has that.
  20. Starship16
    1,348
    1,455
    Beach Christmas
    I don't have it.
