Brand new 12V battery; still dying
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SamusAran, Mar 29, 2017.
  1. SamusAran
    SamusAran New Member
    Utah
    For a couple of months now my 2008 has been dying with increased frequency. I've had to do a lot of jumping.
    Sometimes when I shut the car off and open the door it beeps as if the key is in it but its not. It's not the doors or the lights. Sometimes the master warning light comes on. Sometimes nearly every warning light comes on.
    I had the battery checked and it was bad so I bought a brand new Optima one. It started up fine but a couple hours later it was dead. I jumped it and drove around town then later this afternoon it was dead again.
    It looks like although the battery was bad, there is another underlying problem that's draining the battery (bad inverter from jumping?). If anyone has any experience with this I'd really appreciate it. I've seen a lot of the same symptoms on here but the solution is never updated on any of the threads I've read. Thanks!
  2. JC91006
    16,936
    8,647
    You should check the car for codes, the warning lights mean there's a problem.
    In the meantime, charge the 12v fully before you use it again
  3. cobaka
    cobaka Junior Member
    pennsylvannia
    And check the 12v battery's ground cable; negative post to rear body wall. I just went thru this. The ground was not tightened, and was very loose. I removed the 12v, charged it was 24 hours, and put it back, with the cable tightened. After 2 batteries doing the same as yours, it was a ground cable.
    ITBland, valde3 and bisco like this.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Do you have a volt meter to check the battery?
  5. cobaka
    pennsylvannia
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  7. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
    To that end, what is the voltage when the car is READY?
  8. SamusAran
    Utah
    I don't have a volt meter. I purchased and had the battery installed today though. I started it immediately after installation to see if it worked and shut it off. About 2 hours later I tried again and the dash lights went crazy for a second then the car wouldn't start. I have a habit of leaving the smart key in the cup holder when I'm home but could the smart key really discharge a brand new battery within a couple of hours (assuming the battery came fully charged)?
  9. cobaka
    pennsylvannia
  10. andrewclaus
    993
    326
    Golden, CO
    If you're going to try to work on this yourself, an inexpensive digital volt meter will be one of the important tools. Harbor Freight Tools often gives them away, literally, with a coupon. A set of small metric combination wrenches will be another, to allow you to check and clean the negative battery connections.
    And as mentioned above, if the check engine light is on, something has failed. You need to get the codes or we're just guessing. Some auto parts stores will scan for free, but they use generic scanners that can miss some critical Prius-specific codes. It would be a start, though, for no cost. You may need to pay the dealer's diagnostic fee, or purchase a scanner that's programmed for the Prius (Mini VCI for example).
    I agree, the key did not cause this problem.
    jerrymildred likes this.
  11. Mendel Leisk
    42,354
    Stop doing that, recharge the battery with a smart charger, see how it goes.
    Also, no matter how secure your situation is, that's like leaving signed blank checks lying around.
  12. fuzzy1
    10,713
  13. andrewclaus
    993
    326
    Golden, CO
  14. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    But OP can still use the MFD volt meter to check that charging voltage (voltage when Prius is READY) is about 13.8V or more.
    If it’s not then maybe there is a problem with inverter converter. Are there any fault lights on when READY?
    If charging voltage is fine then maybe there’s a problem with battery cables. First check that terminals are tight on the battery. If those are fine then Prius battery ground cable can have problems in couple of areas:
    -Connection between body and cable terminal (see if it’s rusty or lose)
    -Crimp between the cable and cable terminal (see if corroded and/or lose)
    If all of those are fine then it either is parasitic draw or bad/empty 12V battery. Battery being empty or going bad can be caused by leaving the key in it the Prius. If you have to leave the key in it turn the smart key system off with the button bellow steering wheel.
    You need a current meter to check for parasitic draw.
