Brand new owner (hi!)/question about freeway driving
Discussion in 'Newbie Forum' started by heatherslp, Aug 26, 2012.
  1. heatherslp
    heatherslp New Member
    Pacific NW
    Hi all! I just bought a used 2007 Prius. I noticed that at high speeds (freeway driving) I feel a slight resistance, almost as though it's braking or lowering gears or something. Since this is the only Prius I've driven, I don't know whether this is normal or if I need to have it looked at. Any advice is welcome! Thank you!
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Are you driving in B mode?
    Where are you located? Can you update your location info?
    As for "slight resistance", well, from looking at ScanGauge II bta (amps going into/out of the HV battery), if you're not pressing on the accelerator, there's always a bit of regen going on , which would cause a bit of slowing beyond what's caused by aerodynamic drag and rolling friction.
  3. heatherslp
    Pacific NW
    Nope, not B mode. I'm in OR. I don't think I actually slow down (my MPH doesn't change), I just feel this slight resistance which I figured may be from the regen, but wanted to make sure it's not a problem that I need to have looked at. I attempted to describe this to my Prius-owning friend and he didn't know what I was talking about, which made me wonder if there's a problem. He doesn't feel anything.
  4. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Assuming your friend has the same generation (model year 04 to 09) of Prius, perhaps try swapping cars briefly to see if you each feel/don't feel the same phenomena?
  5. heatherslp
    Pacific NW
    That's the plan. His is a 2012, though. I'm sure I can find someone else with my generation and try it out. So it sounds like you don't really feel what I'm talking about either, right? Or maybe you're just used to it by now?
  6. bisco
    52,855
    yes, i have never felt this. there is some regen going on when you let off the pedal but any car will slow down. there is no regen if you have a steady pressure on the pedal. can you better describe the conditions when this happens?
  7. heatherslp
    Pacific NW
    Driving on flat, open freeway around 50-60 MPH when I'm barely pushing the accelerator or letting off the accelerator. Sounds like I should take it to Toyota?
  8. bisco
    52,855
    not necessarily, that is when you might feel some regen. how's your mileage?
  9. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    I recently bought a 2007 too... I live an hour or so north of Oregon...
    Send me a direct message if you want to compare cars next time I'm heading down the I-5. For now at least I suggest you put the car in neutral while driving and see if that feels different to you compared to when your car is gliding (foot depressed slightly after accelerating and no arrows on your screen indicating electric or gas engine providing power or regenerating power).
    Have you read about how to get highest MPG with pulse and glide around town, as well as how to pulse and stealth mode while on the freeway? That might clear up some of your concerns.
    Also, you could try jacking up each wheel and making sure it spins without much friction?
    PS: Taking it to Toyota should always be a last resort... I read the craziest stories about Toyota dealers on here. They're som bad apples you'll want to avoid out there. You're better off using PriusChat and DIY as much as possible to keep repair costs down.
  10. heatherslp
    Pacific NW
    Okay, I've given myself a week and have some updates. Please excuse my ignorance in explaining these things. I don't have the Prius lingo down yet.
    1. Regarding the freeway issue: it seems like it's shifting between modes and I feel it. I watch the diagram and see the lines and colors and arrows changing, and it all matches up with what I feel. However, sometimes it doesn't stay in any one mode for very long, so it's an abrupt "shifting" back and forth of sorts that scares me.
    2. In town, my MPG is sucking. I drive 4 miles to work and average about 35 mpg. I had my friend drive it last night to compare to his 2012 and he was shocked by how low my mpg goes when he "pulses." It goes into the single digits on a regular basis. Is that normal for this generation? He said his never falls below about 25 mpg.
    Any ideas what might be going on? The car is still under warranty (which is why I'd take it to the dealership) with only 38,000 miles on it.
    Thank you all for your help! This site is awesome.
  11. PriusCamper
    13,465
    5,431
    Yea... Single digit pulses do happen on occasion but mostly low double digits on a heavy pulse... If you're driving 4 miles to work on a completely cold engine 35mpg is typical... For me, unless it's hot out, I need about 10 minutes of engine warmup in city driving to get get out of the 35mpg range. Because of this very issue I'm thinking of getting off my nice person and walking an biking more and only using my car for trips that take greater than 10 minutes.
    And even if the engine is warmed up I know a pro snowboarder women who drives her 2009 like a race car and she always gets 35mpg in the city.
    Point is, getting good gas mileage is a DIY thing, it's not something the dealer can help you with until you car throws a code...
    Fortunately there are loads of things you can do to improve MPG if you spend a couple hours reading as much as possible on here. Pumping up your tires till you find out how much is too much is #1, driving habits is #2.
    And doing all the additional things you read about on here combined is what will get you better MPG. It will also get you doing your own preventative maintenance and in general make your car last alot longer.
    PS: What part of Oregon do you live in? If you live along the I-5 we could meet up and try each other's cars next time I head south, I'm averaging about 49mpg city and 53mpg hwy. When I first got the car 6 months ago I was getting MPG in the low 40's.
  12. bisco
    52,855
    you might need a new 12v.
  13. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    The arrows changing in #1 is totally normal. I put together
    to demonstrate power flow back/forth at highway speeds for another board. I had the cruise control set the whole time. I believe there was a net elevation loss on that stretch (I can try to confirm w/Google Earth), which would explain the high iMPG values at that speed.
    As for #2, it can be normal, esp. if SoC of the HV battery is low. If you want FE help, answer the questions at Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat. Your short drives are killing your mileage. 35 for a drive that short, esp. if it's just city w/lots of stopping, isn't necessarily abnormal.
    See ConsumerReports.org - Most fuel-efficient cars. Last page of http://www.consumersunion.org/Oct_CR_Fuel_Economy.pdf describes their tests. Best & worst fuel economy can give you context of how other vehicles do in CR's short city test.
    What if you get your car warmed up (very important), take on the highway, set the cruise control at somewhere between 50-65 mph, reset the trip computer and drive for at least 5 minutes? Then, turn around and go the other direction (to cancel out effects of elevation change and wind) at the same speed. Tell us what mpg you get from that.
  14. cwerdna
    12,545
    2,125
    SF Bay Area, CA
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Your Hybrid battery may be consistently low. Tell us the charge on the Hybrid battery. Its the other screen from consumption. The one that shows the charge level of the Hybrid battery. Should always be in the blue at least 3 bars.
    And more importantly should not show any wide swings from blue to purple. But if always one bar blue or orange the car will run very poorly with no power and will feel like a load is on it holding you back.
    OR...you are coming from a more powerful and heavier car and not used to the feel of a Prius. I have a cop car I bounce back and forth from and due to the inertia of a heavier and more powerful car it rolls much better and you hardly have to keep the gas pedal engaged to maintain say a 65 mph speed. The Prius is a little different in that you must keep the gas pedal engaged a little more to maintain speed comparatively. But if I drive just the Prius consistently that feeling goes away. You may just not be used to it.
    What car are you coming from?
    A 4 mile commute everyday is not what an 07 Prius is designed for. That will not charge the Hybrid battery or the 12 volt battery very well and your mileage will suffer.I also get 35 mpg's bouncing around town short commute.
    But not sure where you bought the car and if it has a warranty but if it really bugs you and you suspect the Hybrid battery is having an issue go to a Toyota dealer and ask them to diagnose the Hybrid battery. They will hook there laptop to it with proprietary Toyota Techstream software and take it for a spin. They can check all levels of Hybrid battery health and can tell you immed. if they see anything wrong. They usually charge a $125 diag fee.
    Also be aware you really should change the little 12 volt auxiliary battery in the trunk. Comparatively mine lasted exactly 5 years to the month and I took very good care of it with monthly maintenance charges and never jumped it once. I thought that was spectacular performance of the tiny little battery. You do not want to get caught out with that little 12 volt battery dead and the car won't start. The proper connections to jump start a Prius are not well known and alot of people have seen even experienced people damage there car extensively buy reverse jumping. Hundreds of posts concerning that nightmare here also.
    Search here as there are literally thousands of posts concerning that battery replacement. I bought a higher performance Optima Yellowtop just 2 weeks ago.
    Go online to Advance Auto parts and there a 15% off 199.00 deal going on. Buy it online and pick it up at there store. Great deal with a $50 coupon included.
    I highly recommend it.
    Good Luck.
  17. PriusCamper
    13,465
    5,431
    Thanks ED, Just did a search for Advanced Auto Parts in Washington & Oregon and we don't have any of those out here.
    Anyone out there know of a good place for us Pacific Northwest folk to get a great price on a Yellow top?
  18. Drafty01
    Drafty01 Junior Member
    42
    Auckland, New Zealand
    Maybe installing a block heater (to electrically heat the engine) would be an option for you. The car won't burn all the gas heating up, just in time to get to work, it will be warm when you start off. There is a bit of an installation procedure though, which is on one or more of the modding forums. Maybe you've read these by now...
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    BatteriesPlus stores carry them also. If have to ship in use eLearnaid.com
