Brand New Owner w Newbie Question
Discussion in 'Gen 3 Prius Main Forum' started by GreenTerrorPrius, May 25, 2020.
  1. GreenTerrorPrius
    GreenTerrorPrius Junior Member
    56
    So I just bought a 2012 with only 49k miles. Got a real good deal at 6250, but I am pretty sure the hyrbrid battery is going to need replaced. I only have about 3 bars on it when I drive ont he display, it will sometimes get up to 6 but then goes to 3. I am sure this is mostly as it doesnt look like it was driven much.
    Is this a fair assessment, thanks to all as I know this is a newbie question.
    GTP
  2. Tideland Prius
    16,680
    It does sound like a weak battery or one that is on its way out.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. You don't have NEARLY enough information to jump to that conclusion.
    Under many circumstances, the system will keep the charge level in the middle somewhere.
  4. Mendel Leisk
    42,347
    Does the displayed charge drop/climb quickly? If it's gradual, I think it's less likely to be problematic, just due to driving conditions.
    If you're driving on level roads, say 30~35 mph, engine fully warmed, the car will tend to slip into electric-only, and will happily eat up the charge. If this goes on more than a mile, you'll run it down to two bars easily.
    Another scenario: you're tooling around a parking lot, looking for a spot. Here again you're pretty much level, and the low speeds (basically crawling) means you'll almost for sure be electric-only, and will eat up the charge fast.
    If you're driving again around 30~35, but more stop-and-go, encountering traffic lights, stops, there's curves, rises and descents, then the engine will tend to stay on more, you'll just have brief electric-only stretches, and the charge should settle in somewhere around 2/3.
    If you take it for a highway drive, say 50 mph or more, the car will never be electric-only (the upper threshold is something like 45). In that condition, after 10~15 minutes driving, if the battery is ok the charge display should for sure be up around the 2/3 level or better.
    I would just give it a while, continue to monitor, and post updates. You might also look into a phone app Dr Prius (you need a bluetooth OBD adapter too, Carista is one that works), see what it says.
    #4 Mendel Leisk, May 26, 2020
  5. bisco
    52,855
    congrats and welcome!
    doesn't sound to bad, but it might be a good time to purchase a hybrid automotive grid charger and start rejuvinating the pack.
    all the best!(y)
  6. bisco
    52,855
    also:
    consider cleaning the hybrid fan and changing the tranny fluid, along with regular maintenance for that many years.
    sign up at toyota.com/owners and input your vin for dealer history
    Tideland Prius likes this.
  7. GreenTerrorPrius
    56
    you guys are awesome...this is all great info. Thanks and I have a lot to do and monitor now!
    Raytheeagle, bisco and Mendel Leisk like this.
  8. Montgomery
    Montgomery Senior Member
    2,254
    2,243
    Orange County, CA
    You have a lot of things to check. Look at doing all the previous replies. My question is, Who did you buy it from and what previous maintenance has been done?
  9. GreenTerrorPrius
    56
    2 owner car that was serviced at the dealer the entire time. Looks like oil got changed regualry at 7500 miles
    Drove it tonight for a lot longer and had half bars and then even one more....good news. I think this thing was in a slumber for a long time and just wanted to be driven! This is my first Prius....these things are Awesome! It told me for my 6 mile drive i got 48mpg!
    Bisco thx for the Toyota owners tip....i can see all the service records now. Even thought when I did a Vincheck online it showed no acccidents it looks like it got into a fender bender of some sort as look at these parts it got in a service call:
    COVER, FR BUMPER L/P
    5211947934
    SUPPORT, FR BUMPER S
    5211547041
    SEAL, HOOD TO FR END
    5339547020
    REINFORCEMENT SUB-AS
    5202147012
    BRACKET SUB-ASSY, FR
    5701347040
    5701447040
    COVER, FR BUMPER HOL
    5212747903
    GRILLE, RADIATOR
    5311147040
    JAR, WASHER, A
    8531547140
    PIPE, WASHER, A
    8531947120
    UNIT ASSY, HEADLAMP,
    8113047520
    LENS & BODY, FR TURN
    8151147060
    BRACKET, FR TURN SIG
    8151947060
    8151947040
    8151947050
    5380347020
    TUBE & ACCESSORY nice person
    8871047150
    HOOD SUB-ASSY
    5330147050
    HINGE ASSY, HOOD, RH
    5341047070
    HINGE ASSY, HOOD, LH
    5342047070
    LABEL, COOLANT SYSTE
    1128537060
    LABEL, EMISSION CONT
    1129837350
    LABEL, COOLER SERVIC
    8872347090
    LABEL, BATTERY CAUTI
    G927576020
    FENDER SUB-ASSY, FR
    5380147040
