BRAND NEW! Prius Chat User - over 110k miles
Discussion in 'Newbie Forum' started by eDad, Feb 17, 2017.
  1. eDad
    eDad Junior Member
    Just want to introduce myself from Miami FL
    2008 Lipstick Red Prius (not sure if its touring) Over 118k, out of warranty, now taking maintenance into my own hands
    - Currently needs an oil change (maintenance light on)
    - the red warning symbols appears every once and a while when I brake or turn too hard ???
    - terrible mileage
    Will need plenty of help, thanks for being here guys!
    #1 eDad, Feb 17, 2017
    Honey2017, Burna J and bisco like this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Easiest way to tell if it is touring, if it has 16 inch wheels it is, if it has 15 inch wheels it is not. The rear spoiler is longer on touring.
    Best of luck! Welcome to PriusChat!
  3. eDad
    eDad Junior Member
    Thank you Jimbo, so swift with the response! I also have other questions as well, just updated.... again thank you Jimbo!
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Usually, you are low on some fluid, most likely oil, that gets too low when g-forces push it horizontally. Try topping up low fluids: oil, engine coolant, inverter coolant, (same fluid, different loop) brake fluid, washer fluid, etc. if they look low.
    If it is new to you, clear all trip odometers and measure gas mileage again.
  5. eDad
    eDad Junior Member
    DAMN JIMBO YOU'RE THE MAN,
    well aware of the odometer situation, but thank you anyway
    satisfied user, will come back soon Jimbo
    RCO likes this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Once you have questions needing in depth answers, you will find others are the true stars here. I try to handle easy stuff quick;y so they can focus on the challenges. (I am a fanboi of Bob Wilson and Patrick Wong just to name two of the greats)
    (I serve the same function answering networking questions here Networking Matrix - Ars Technica OpenForum Taking the easy questions so the experts can think about the hard ones)
    SFO likes this.
  7. bisco
    52,740
    welcome! looks like jimbo has you covered, all the best!(y)
    #7 bisco, Feb 17, 2017
    RCO likes this.
  8. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Yup, he was serious about checking the oil. If you are low enough to trigger the light on corners, you are in the danger zone. Top off until you do that needed oil change!
    eDad likes this.
  9. Prodigyplace
    12,709
    11,847
    Central Virginia
    Welcome!
    bisco, is Jimbo that fat?? :LOL:
    RCO and eDad like this.
  10. Honey2017
    Honey2017 Junior Member
    71
    17
    US
    Doy tune up. Pretty easy. Spark plugs pvc valve oil trans fluid air filters but when you get that red triangle have a diag done at an auto zone its free if you go to toyota theyll charge you like 100 bucks. The triangle could be your 12v. Also check your tire pressure that can affect gas milege as well. My guess tune up an new 12v an tire pressure check. The amount of air for tires are on your drivers side door i believe tells you back tire pressure an back. Make sure your tires are these pressures to get the best gas milege
    If you need help on the tune up let me know. Iam a female an did it myself.
  11. eDad
    eDad Junior Member
    Posted via the PriusChat mobile app.[/QUOTE]
    Thank Honey2017!!! I started a new thread with for my NEW A/C ISSUE ::sarcasm:: & MPG issues because it definitely was a low amount of oil that was triggering the red triangle. But my problems now could be battery related. I can't tell yet. Im getting absolutely mad at the fact that this might end up going back to the dealership. Community, help!...
  12. Market05
    Market05 New Member
    27
    Western Maryland
    The good news is that you should be able to tackle any of the systems on the Prius for $1k or under by diagnosing and doing the work yourself. If battery, read up on replacing bad cells yourself. They can be bought for $40-50 a piece online. I think there are 35 or so of them in the battery pack.
  13. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Easiest way to tell touring (from a distance) is 16" wheels have 7 spokes (15" regulars have only 6 spokes) - (just sayin') BTW Welcome to PriusChat! (OK, I know I'm late to the party (…so what's new?)) you'll love it here, some great people, and a few old curmudgeons like wot I am! :eek: :rolleyes:;)
    RCO and Prodigyplace like this.
  14. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
