Break actuator replacement.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Jan 6, 2022.
  1. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    Hello all I took my car to the dealer and they tell me I need to replace.
    they tell me I need this part Break booster Assembly prt # 44785-02060
    Can you guys help me find this part I cant seem to find it on the toyota site.
    Further more they want 1171.38. I live in montery ca so any dealer in the bay are would be good.
  2. ChapmanF
    19,038
    Are you sure that estimate hasn't got a date of April 1st?
    That part number they gave you is for a gasket for the brake booster. It's about four bucks. You can see it in the far right of this picture. :)
    The big ol' boxy part just to the left of that gasket would be the booster assembly they're wanting to sell you.
  3. johnnychimpo
    522
    112
    Monterey
    yup wrong line item sorry... here it is 04002-33347
  4. johnnychimpo
    522
    112
    Monterey
    So found the part, which brings more questions.
    1.is it me or do some dealers want you to reach out to them to buy parts as some sites seem to have removed the lookup and replaced it with send your part number needed, vin and contact info.
    2.My original part is 4721047140 and my local dealer wants to replace it with 04002-33347. So the part they recommend would this be plug and play or would it need to be programmed?
    If it needs to be programmed can my local shop do this?
    My plan is to buy this part here and install it and have my local shop bleed and program it.
    Thoughts anyone??
  5. Mendel Leisk
    42,355
  6. johnnychimpo
    522
    112
    Monterey
  7. ChapmanF
    19,038
    Ah, that's more in the ballpark I remembered.
  8. johnnychimpo
    522
    112
    Monterey
    I think my local dealer is a rip off I think he tried to sell me the most expensive part he could find.
  9. johnnychimpo
    522
    112
    Monterey
    So how do you know if you will need to program the actuator?
  10. ChapmanF
    19,038
    I don't think programming is needed, other than the small procedures described in the manual, like learning the solenoid offset, which if it needs to do, it will tell you by setting the code that means that, and then in Techstream you say "ok, so do that", and it does.
    Now, it's possible that the units sold for use in different car models are "programmed" with different calibrations of the software, and that could be sticky business, if you pick one up that was meant for a different model. I know there are different calibration IDs for 2010 between the trims that came with 15" and 17" wheels, for example.
    It's possible the dealer could reflash one, if it came down to that; they do have reflashes available for TSBs. They don't really advertise being able to do that from one application model to another.
    If you can connect to the thing with Techstream, you can find out its current calibration ID, and compare to the ones listed in bulletins for your model, to see if it's one of those. T-CP-A0B-0001-D is one bulletin I know of that has brake calibration IDs listed.
  11. johnnychimpo
    522
    112
    Monterey
    As luck would have it all my attempts to get this part have failed. my last resort is this part i found NIB on ebay, is it compatible?
    47210-47310
    Genuine Toyota Brake Master Cylinder 47050-47140 | eBay
    the part does not match the box but it does have the EC initials like mine. Why are there so many versions of this part my goodness!!!!!!!!!!!! do the more expensive ones make you breakfast in bed? what justifies the price if they all do the same thing.
  12. ChapmanF
    19,038
    Not every number you see on a part is a part number. You can see "47210-47310" on a part itself, but if you do, you are looking at a 47050-47140 part (or the older part that 47050-47140 has superseded, and 47210-47310 wasn't the part number of that older one, either). Yes, it's tricky.
    So here's what you do, you go to Toyota's own parts site, you look by 2010 Prius, and you see these two choices for the part;
    2010 Toyota Prius Brake Master Cylinder. Brakes, Leak, Repair - 4705047140 - Genuine Toyota Part
    2010 Toyota Prius Brake Master Cylinder. DISC, TIRE, WHEEL - 4705047150 - Genuine Toyota Part
    So you have to decide which one is right for your car. You click each one and look. When you click the top one, you see it says the mark on the part can be 47210-47310 or 47210-47140, and under "what this fits" you can see 2010 hatchback and L grade.
    When you click on the second one, you see its "mark" can be 47210-47320 or 47210-47150, and it goes on 2010 G or S grades with the 17 inch wheels.
    Your profile says you have a three, so I would expect you want the first one. What is the mark on the one in your car?
    You can see this post (and the one after it, from Elektroingenieur) for more on the relationship between orderable part numbers and the marks on the parts themselves.
    Often used part sellers online will not be paying attention to that, and they will list the mark they see on the part as if it were the part number.
    PriFi and Mendel Leisk like this.
  13. johnnychimpo
    522
    112
    Monterey
    Sorry what is the mark exactly?
  14. ChapmanF
    19,038
    The number you can actually see on the part itself, which some online sellers mistake for the part number.
  15. johnnychimpo
    522
    112
    Monterey
    is that the number below the initials mine being EC then the number bellow 47210-47310 in my case the 47210 is the part number ?
  16. johnnychimpo
    522
    112
    Monterey
    ChapmanF your contribution is greatly appreciated, are you retired you are always on here?
  17. ChapmanF
    19,038
    No, the confusing thing is that Toyota part numbers all look like some xxxxx-yyyyy, and so do the marks printed on parts that are not part numbers.
    In your case, 47210-47310 is the mark on the part, but 47050-47140 is its part number (which you will not find on the part).
    PriFi likes this.
  18. 4-robinsnest
    4-robinsnest Junior Member
    Polk City, FL
  19. 4-robinsnest
    Polk City, FL
    Hello ! Mr. ChapmanF
    On this same subject, We were told by our Lakeland Toyota Dealer 11/3/'22 that our 2012 Prius V-2 VIN# JTDZN3EU9C3105757 needs a brake master cylinder Part# 4705047110 They are telling us that part alone is $1,683.00 ?? Labor = $600.00+
    We have purchased parts from the Stuart, FL Toyota Dealer Certified Used in the past for a more economical price and they are telling us that they need the Actual # off of the Part that is to be removed to be sure of the Compatibility of the Replacement part due to the electronics involved ?
    The Mechanic at the Independent shop does not want to remove the existing part until he has one that will be shipped to replace the one that he is removing (that we need the Part# off of ?) Is there anyway that we can tell by the above VIN# what the actual part # would be on our 2012 Toyota Prius V-2 ? Or do I just Crap Shoot and order the:
    $1,229.99 https://www.ebay.com/itm/403255583341?epid=661912836&hash=item5de3e7e26d:g:6P8AAOSw6S1hdtkT&amdata=enc%3AAQAHAAAAoKy1TtZuLaB%2BRB479B7e6Dz5iZ0lL8pXUP1v9dGmr2JJOavc0II5StBHeAARdpIJmXMzYhdQ6oeo9KhfBfv6bysimMH3oyNxuT7izmKQTIm3a4deGEg7CO6lvt%2BBhu74iG%2BdROFuPBN6gcyvO7odOZshtU1DnetRNRef%2BTKDtIpHSFmC2OLkmFtOoOQUMDhUDjfCXiyI7UUAxzEKqdhAqOQ%3D%7Ctkp%3ABk9SR5jL6quKYQ
    Or the :
    $624.99 https://www.ebay.com/itm/285007577732?epid=658164860&hash=item425bc68284:g:OH4AAOSww0JjUCdF&amdata=enc%3AAQAHAAAAwPPJLfsl4P9l5%2FkW7EfRTzn8d2WKQMQOrbMuA%2F7XIenxgY3e%2Bn9aZctZfM1seUcuvDFis4ahPJz5vxnLuyb1%2F%2FnYZeQSDY8XomuSudfZ8ZysAccBolC7LXxnoV9OhLKhEfbaNVt8GfkOaFD9QUWw6i%2BdSbU6IpDp5jemfULoUjBRn6vzuBGmT3L6uZqkTEgXno0XUFleeoD69clFhX6jxDPCZiuUUGydUk729CmsX1J2zsQXrC0WH3mmS9WeYPjjKQ%3D%3D%7Ctkp%3ABk9SR4i6uoKKYQ
    Which the above both items from Treasure Coast Toyota of Stuart, FL list my Year/Make/Model as Compatible but this Dealership says to be sure they need that Part # that my Mechanic does not want to remove to disable (the already disabled[had to be towed] Prius) Please Advise as my Economical Nature says to order the $624.99 part and then the Mechanic will pull the Part (then we will have the Exact Part Number) and if the $624.99 part does not work, I will return it and have the Information that the Stuart, FL Toyota Dealer needs to Cross Reference the Original Part # to the Replacement Part # to find the most economical exact match of the Part needed ? Why is this so Complicated ? [email protected] a.k.a. 4-robinsnest
