Break clicking noise
Discussion in 'Gen 3 Prius Main Forum' started by capolihu, Aug 14, 2021.
  1. capolihu
    capolihu Member
    101
    76
    Mont
    anyone has an idea what this noise is, when I break around 20mph and turning the wheel? I think I'm not getting it when there is no turn.
    52,863
    probably a cv joint, but i can't hear it
    Danny3xd () likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,121
    6,977
    Texas Hill Country
    Typical cv joint, have it checked because if it is a cv it could strand you without warning. Don't break your car when you are trying to brake.
    #3 rjparker, Aug 14, 2021
  4. capolihu
    capolihu Member
    101
    76
    Mont
    Neither MP3 nor mp4 can be uploaded.. :(
    What is CV joint..?
  5. capolihu
    capolihu Member
    101
    76
    Mont
  6. rjparker
    11,121
    6,977
    Texas Hill Country
    Mp4 sounds like wind noise. A cv joint is on your two drive axles.
  7. capolihu
    capolihu Member
    101
    76
    Mont
    Yes it stars with wind noise the if you listen you will hear it
  8. rjparker
    11,121
    6,977
    Texas Hill Country
    A cv joint is a multi direction bearing assembly on your front drive axles. Two joints on each front axle. They have a rubber boot around them to protect the bearings from dirt and water. If the boot rips, grease inside is lost and dirt and water gets in. Which often causes failure. The cv joint can break causing you to be stranded. Best to have someone check them. Other noises are not as immediately serious. 147CED9A-6FB3-48D3-8C89-6AF3A93C6BC2.jpeg
  9. capolihu
    capolihu Member
    101
    76
    Mont
    Yes, I see your point now. The Toyota service however said it is the break pads that are not by T factory and a bit bigger. I don't necessarily trust them, will swap it and let the community know
