break light switch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sambenjamin, May 3, 2020.
  1. Sambenjamin
    Sambenjamin New Member
    Long Beach, CA
    My prius was experiencing trouble going into ready mode sometimes. I came to the conclusion that it was the break light switch because when the break light wouldn't come on, the car would not start. I replaced the break light switch and now it will not start at all. Is there a fuse I should check or something to reset?
  2. JC91006
    16,939
    8,647
    Did you plug in the brake light switch? Did you use an original part and not aftermarket?
    If the brake light switch goes bad, it would have a code to let you know it's bad. You don't really have to guess at it.
    If the installation of the brake switch is correct, then you probably drained your 12v while installing the brake switch
    SFO likes this.
  3. Sambenjamin
    Long Beach, CA
    Is there a fuse for the break light? I cannot seem to locate it
  4. JC91006
    16,939
    8,647
    I'm not sure if there's a fuse for it. The fuses are located in 2 places, the engine compartment (where you jump start the car) and under the steering wheel.
  5. dolj
    dolj Senior Member
    8,654
    4,404
    Wellington, New Zealand
    Did you plug in the brake light switch? Did you use an original part brake light switch or did you use an aftermarket brake light switch?
  6. George W
    George W Senior Member
    939
    520
    San Antonio
    I wasn't aware that the Prius had a brake light switch.
    I've owned Nissans with the brake pedal that pushes against a button-switch to close a circuit for the brake lamp. This button switch has a rubber o-ring in between it and the pedal, and it gets brittle with age. When that rubber fails your brake lights come on and stay on until the battery is drained. In the Nissan at least, a 'always on' brake light is the indicator that your rubber o-ring has broken apart and it's no longer separating the button and the brake pedal
    Anyway, I'm sorry to get off topic. This is the first thread I've ever read about the Prius having brake light switch
  7. JC91006
    16,939
    8,647
    It's the same button switch as your Nissan
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Have you already checked the voltage at the 12v jump points under the hood, sometimes the battery can be run down during a repair.
    If the vehicle doesn't start there could be codes (DTCs) stored in the ECUs, some prefer using an OBD2 scanner to read the codes before attempting to diagnose or repair. Many auto parts stores can scan you car for free, even if the offered OBD2 scanner isn't hybrid compatible.
    Have you ever experienced any dashboard 'blackout' issues, or various warning lights appearing on the dash?
